Home Forums Vinyl Cutter Discussions Roland Cutters can anyone advise why my cadet is cutting poorly?
  • can anyone advise why my cadet is cutting poorly?
    Posted by Graeme Speirs on 18 December 2007 at 10:47
    hi,
    just running some stickers on my cadet and the cut is very poor ie: edges of square stickers very untidy, does anyone have advice on how to improve this? its not the blade as I hardly use the cutter?
    graeme
    Graeme Speirs replied 17 years, 11 months ago 3 Members · 4 Replies
  • Derek Heron
    18 December 2007 at 11:08
    Hi Graeme that could be it if its not used it may just need a bit of lube or a clean out
    Derek
  • Graeme Speirs
    18 December 2007 at 11:22
    thanks derek,
    where does the lube go? (cue double entendres galore!!)
    graeme
    18 December 2007 at 11:41
    I think it more likely is your blade. This happened to me very recently with a blade that was only weeks old – turned out the tip had broken off (very difficult to see , but if you look hard you should be able to tell if this is the case or not). Try a new blade first. If you haven’t got a spare get one anyway because you will eventually need it.
  • Graeme Speirs
    18 December 2007 at 15:56
    thanks phill, actually I think that is what happened before come to think of it, I have plenty spare blades so will try it out.
    graeme
