Home Forums Software Discussions Corel Software Can anyone advise regarding the application launcher?
  • Can anyone advise regarding the application launcher?
    Posted by Robert Scullion on 24 June 2005 at 11:16
    Can anyone advise regarding the application launcher in corel, I click on the application launcher, select coreldraw to signlab and get a message saying "Can not find Signlab excutable, do you want to locate it yourself?
    Not the most computer literate guy in the class, can anyone advise
    Bob
    Peter Shaw replied 20 years, 5 months ago 6 Members · 8 Replies
  • 8 Replies
  • Andy Gorman
    24 June 2005 at 11:21
    If you have a shortcut to signlab on your desktop or in your start menu, right click on it and select “Properties”. Then look at the text that follows “target”. This is the path you should follow when locating the application yourself. Simply follow this path in Corel. The application file should be something like “signlab.exe”.
    24 June 2005 at 11:22
    Not too sure about the app launcher, but if you want to move a file from corel to signlab you can export is as an ai or cmx and either of those will import into signlab no problem.
    marcella
  • Rodney Gold
    24 June 2005 at 11:31
    We just cut in Corel and paste into SL (ver 5)
  • Robert Scullion
    24 June 2005 at 11:49
    Thanks guys
    Was able to use application launcher in corel when I used sl6, now I’ve got sl7 it wont do it
    Using Marcellas method now but thought it was easier c/o the app launcher.
    Will try Big G’s suggestion.
    Thanks again
    Bob 😮
    24 June 2005 at 12:20
    The app launcher is essentially cut and paste I think but mine doesn’t seem to support colour if the colour model is Pantone – RGB and CMYK is ok, exporting as ai/eps seems ok.
    Alan
  • Peter Shaw
    24 June 2005 at 18:12
    As I recall the application launcher ceased to work with Corel after version 8.
    If you are using V8, Signlab must be installed after Corel so that it can amend Corel.
    If you can’t get it to work then use EPS file transfer.
    25 June 2005 at 08:03
    App launcher works here in corel Draw V12. If Signlab is not running it launches Signlab V6 but if SL V7 is running it puts it into that. EPS/Ai /cmx export or cut and paste all work as well.
    Alan
  • Peter Shaw
    25 June 2005 at 08:45
    I think my earlier post must relate to Signlab 5 and Cadlink redeveloped the app launcher for V6 onwards.
