can anyone advise me with wrapping a van please?
Hi All
I am in the process of quoting for the wrapping of an Iveco Luton van. Its a 57 plate and the sides are nice seamless totally flat panels, and the ‘Luton bulge’ bit above the cab is 1 piece moulded fibreglass, again nice and smooth. The customer wants 3 quotes, one for just wrapping the side panels, one for the sides and the bulge, and one for the whole thing (tail lift on the back so this won’t need doing).
I have several questions and would really appreciate it if someone could help me out as this is my first wrap. (I have been on the Roland course however).
I was planning to quote based on using Oracal 3551 bus wrap for the panels, and 3951 for the cab and bulge, both with the correct Oraguard laminates, but I think upon further inspection that I will find the bulge is not actually painted and therefore could be classed as a low energy material. Is it best to just not wrap it? I’d rather do that than have it peel off after the first few miles!
Also, the side panels are 4m x 2.1m. Allowing myself a 100mm bleed (too much/not enough?), this gives me a total print area of 19.3 square metres, which I reckon is about 15-16 linear metres on 1370mm material. What kind of pricing structure would you reccommend as my usual metre rate just doesn’t work with this area and material. I am allowing myself 4 hours for the labour to produce and laminate this material, and 4 hours per side to prep and wrap. I will hopefully have some help but just an extra pair of hands really, not a qualified fitter.
Would it be ok to let this amount of print gas off loosely rolled as I don’t have space to lay it all out?
As you can probably tell I’m a little nervous about committing myself to a price before working these things out, and am not sure what the market will stand for a wrap of this type, as most of the application is onto a totally flat surface. What would you charge?
Sorry for the long post just trying to get it all straight in my head before submitting my quote.
