Home Forums Software Discussions Corel Software can anyone advise me with a couple of corel draw problems?
  • can anyone advise me with a couple of corel draw problems?
    Posted by Simon Clayton on 7 September 2003 at 08:01
    Hi Gray,
    Try re-installing the program, or upgrade. All your drawing file’s should be safe, but make a backup anyway.
    (or you could be low on memory)
    Second…open first image and then import the second,
    Wait to see if anyone else on the site can come up with other ideas before re-installing corel
    Good luck
    Simon
    Doug Edwards replied 22 years, 2 months ago 3 Members · 3 Replies
  • Alan
    7 September 2003 at 09:41
    As Simon says with importing another image, but unless your going to plant it on top of your original you may want to make room for it. Go to [Image] [Paper size] and add an area of paper where you intend placing the new image.
    The image you import will be a new object that you can manoeuvre on the page into the correct position. Once you’re happy with the position you can combine it with the background to make a single image with your original.
    The alternative to importing is to open the new image in a separate window and simple copy and past it into the original.
    Well that’s all as clear as mud 🙄 😆 😆
    Alan
  • Rodney Gold
    7 September 2003 at 12:11
    First go to view and click the toolbars you want to see
    Then go to tools/options and set all the options you want , ticking “start a new document when starting corel” option
    Then go to tools/settings for new documents and click what you want
    Then all your settings will be remembered as a default and not with each document (which is most likely happeneing now)
    As to the other thing , import and put it where you want or use a program like the freeware Xnview which is a fantastic corel browser , and drag and drop it from the xnview window to the corel one
    (you can do the same with some other graphic viewers)
    http://www.xnview.com
    download it , you wont regret it – its a lovely graphics viewer that does vector and raster and is free
  • Doug Edwards
    7 September 2003 at 13:10
    Yes I have had this problem before and the solution for me was to uninstall photopaint then reinstall from original disk, good luck doug edwards
