Home Forums Vinyl Cutter Discussions Summa Cutters can anyone advise me why im not getting a clean cut?
  • can anyone advise me why im not getting a clean cut?
    Posted by John Morgan on 20 May 2008 at 08:14
    Hello All, thanks to everyone who got back to me a few months ago re a particular problem. I now have another problem !!!??
    Im using a SummaCut D60 with Signtools3/coreldraw12 package, for some time Ive not been having a clean cut, so its snagging on the vinyl every couple of millimetres making clean weeding difficult sometimes. Ive tried new blades and adjusted pressures but still the problems exist ! Any ideas/help ? Thanks John
    Paul S Martin replied 17 years, 7 months ago 8 Members · 11 Replies
  • 11 Replies
  • Peter Dee
    20 May 2008 at 08:44
    Have you checked the nylon cutting strip with a finger nail for any ridges or damage?
  • John Morgan
    20 May 2008 at 10:23
    Hi Peter, thanks for response. Ive just checked that and it seems fine !! John
    20 May 2008 at 10:32
    John is your off set, set correctly, as this can affecting cutting as well.
  • Jamie Wood
    20 May 2008 at 10:44
    Could try a squirt of DW40 into the blade holder. Sometimes a bit of grit
    gets in there & stops the blade rotating correctly.
  • Paul S Martin
    20 May 2008 at 11:40
    Hay Peter
    Sorry to butt In John
    Is the nylon cutting strip a part that is easy to get and replace ???
    Paul
  • Andrew Ritchie
    20 May 2008 at 12:14
    You can nylon strips form most suppliers. They are adhesive backed and take around 5-10 minutes to replace as they sometimes leave glue depending how long they have been on the machine, so may require a clean so it lies flush along the length of the machine. Also remember to test you blade pressure when replacing the nylon strip.
  • Peter Dee
    20 May 2008 at 12:39
    quote Paul S Martin:
    Hay Peter
    Paul
    In a word, yes.
    Order a couple at a time to be more cost effective.
    If your machine has ever run out of vinyl or cut right through then it’s likely to be damaged.
  • Jon Marshall
    20 May 2008 at 13:23
    Anyone know how to get the strip out of a mutoh sc 750?
    It says lever it out with a screwdriver but it is very solidly stuck down.
  • Steve McAdie
    20 May 2008 at 15:36
    try warming it first with hairdryer
  • Peter Dee
    20 May 2008 at 15:50
    You will have to prise it up from the very end first, possibly with a strong penknife blade tip pushed into it and then lever it up.
  • Paul S Martin
    20 May 2008 at 17:18
    Thanks Andrew & Peter
    I will have to order some in the morning as mine do have some small marks in it not bad now but don’t want problems later when works is busy 😕
    Thanks Again
    Paul
