Home Forums Software Discussions Signlab Software can anybody keep me right with print laminate cut?
  • can anybody keep me right with print laminate cut?
    Posted by Derek Heron on 11 July 2007 at 08:53
    i have some work to do which need printed-laminated- then die cut
    can anybody point me in the right direction
    i have cadet plus running signlab 7.1 cant find it in the manuals etc
    thanks in advance
    Derek
    Peter Normington replied 18 years, 4 months ago 3 Members · 4 Replies
    11 July 2007 at 09:17
    Derek the half cut feature is supposed to do it, it does after a fashion, but needs a lot of messing to get it working (well on my mimaki anyway)
    there is a demo on the cadlink site under tutorials.
  • Derek Heron
    11 July 2007 at 14:28
    thanks peter
    just logged on and got a reply from rod so busy going through the tutorial
    thanks for the pointer.
    are you getting an ezy taper yet
    just applied 10 6×3 digi prints to 4mm correx it took more time trimming the prints than it did applying 😛
    managed to print remove and then cut with the reg marks
    can i go home now
    Derek
  • Rod Young
    12 July 2007 at 19:48
    For reference, the InfoSource video tutorial on configuring Half Cut is here:
    http://www.cadlink.com/infoSource/nfo_s … CutPt1.php
    Cheers,
    Rod at CADlink
    12 July 2007 at 20:49
    I watched it many times Rod, and set up as instructed, it’s still is not functional on my set up.
    for instance, if i want to die cut a few hundred decals, and arrange them into smaller groups of say 25, and repeats so reg mark detection allows accurate cuts.
    signlab cuts one group, then asks for a pen change, but then does the next group of contour cut, offset, then prompting for a pen change again.
    try as I may, pen change, tool change, pressure change, I cant get it to work.
    Ray and Bernhard have both tried to set it up, with only limited results.
    it would be good if it worked properly,
    I dont think it is me,
    any pointers would be appreciated,
