Home › Forums › Sign Making Discussions › Neon, LED, Lighting › Can anybody help source a stainless steel projection pole
Posted by Warren Beard on 13 July 2007 at 09:46Hi
Can anybody help me source a stainless steel projection pole to hang a piece of acrylic from. (I would say it needs to be a bit like a banner hanging pole)
Warren
Warren Beard replied 18 years, 4 months ago 9 Members · 13 Replies -
warren havnt seen any myself fabricate some track to go along a banner pole or suspend it of some wire system maybe does it have to be acrylic id do polycarb poss 10mm
i am not 100% what your after, but what i make on what you are after. i don’t know of a stock supplier. i have a stainless fabricator next door to me… in the past i have just had him fabricate for me. hes not cheap or fast, but then again, they do a good job.
Hi Phil
It doesn’t have to be acrylic but the difficult part is trying to find a stainless steel pole as it will be outside she does not want chrome as it will tarnish.\
I think I might need to find a 80mm diameter stainless steel banner pole and modify it shorter, don’t know really 😕
Thanks for the reply
Warren
If you call Ashby’s they have the tolerances on there system,
The easiest way to describe it is a flag pole but only about 2 foot long and attached horizontally to the wall, weld 2 rings on the bottom and hang a sign from it……………… this is what the customer wants 😕
Do Ashby’s do stainless and make bespoke?
Warren
quote Warren Beard:The easiest way to describe it is a flag pole but only about 2 foot long and attached horizontally to the wall, weld 2 rings on the bottom and hang a sign from it……………… this is what the customer wants 😕
Warren
Hi Warren,
(mod-edit) please read board rules (second warning)
Semih,
Please read the board rules, you are not allowed to offer your own services on here.Welcome anyway, Why not say hello in the hello forum?
quote Peter Normington:Semih,
Hi Peter,
Thanks for your warning. I did not read the board rule. Right now i took a quick look the rules. Please say me some advise about this; if the topics are related with my job. Should i recommend other manufacturer? I had just thought, i am manufacturer regarding subject and how can i help if i am not allowed to offer myself.
Sorry for my complaint but i am a new member. Maybe you can orient me for this aspect.
Thank you
semih
None of us are allowed to promote our services, however we can talk about the problem here but we cannot offer our services to do the job.
UKSG paying members are allowed to contact privately as your email address will be removed as soon as the moderators see it.
This place is designed so we can talk about your current jobs, recommend who can do or buy the parts from if you need help on a project.
So suppliers are not allowed to advertise.
Sign makers are not allowed to offer their services publically. -
Warren,
Can’t think of an ‘off the shelf’ solution to your problem, and would
think you may need to have this custom fabricated.We have quite a bit of stainless steel work fabricated for us and we
tend to use different companies depending on the type of steel section
they are likely to stock or production method that they specialise in.i.e. we have a company that make great sign boxes for us, as they specialize in folding work for work tops and benches for the catering trade.
perhaps a company specialising in boat fixtures and fittings may be your best bet. 🙂
Warren
http://www.tradesignz.co.uk make this sort of thing. have a look at the ‘Ject 2’ bracket-I imagine this is similar to what you are after Warren?
quote Lorraine Clinch:quote Warren Beard:The easiest way to describe it is a flag pole but only about 2 foot long and attached horizontally to the wall, weld 2 rings on the bottom and hang a sign from it……………… this is what the customer wants 😕
Warren
Hi Lorraine
I have seen these and sent pics to the customer as an alternative to stainless steel, she liked them but still wants to try get stainless steel and said she has someone who can do it or she will use one of these.
thanks for all the help everyone.
Warren
