Home Forums Software Discussions Adobe Software can a pdf be imported into siglab or corel please?
  • can a pdf be imported into siglab or corel please?
    Posted by Ian Higgins on 19 April 2005 at 14:21
    Hi folks,
    Customer has sent me artwork as a pdf.. I can view it with a free viewer but need to be able to open it in signlab or Corel.. Can it be done?
    If not what softwear do i need
    Ian
    David Rowland replied 20 years, 7 months ago 12 Members · 14 Replies
  • 14 Replies
  • Marekdlux
    19 April 2005 at 14:26
    I always open up PDF’s in photoshop. Not sure if that helps any. I can always open it up for you and re-save if needed. Let me know.
    -Marek
  • Rod Gray
    19 April 2005 at 14:37
    Adobe Acrobat version 6.0 Standard allows you to manipulate pdf images to an extent.
    You can seperate the image etc and export as eps etc.
  • Tim Painter
    19 April 2005 at 15:01
    Depends how it was created I guess.
    In the full version of Acrobat you can save as eps.
    Then import into corel draw.
    Trouble is so many people dont know how to PDF properly and you dont get vectors as they choose options that creat bitmap images.
    Tim.
  • Frank Droog
    19 April 2005 at 15:06
    Signlab 7.1 now has a pdf import filter.
    Otherwise you will need to load it into Adobe Illustrator or Corel as PDF and reexport as CMX or AI or EPS.
    The new filter in Signlab does a pretty good job of keeping vector as vector,text as text and imports multi page pdf files.
    frank at cadlink
  • John Childs
    19 April 2005 at 15:29
    I open them up in Illustrator.
    Vivid, I know how to work pdfs and I deliberately send artwork to customers in a bitmap option. And a low resolution one at that. 😀
    19 April 2005 at 15:39
    I export as eps and then import into Corel. I’d be interested how effective Signlab is at importing a pdf fontwise, ie are the lettershapes retained are does it just latch on to any installed font on system?
    Alan
  • Tim Painter
    19 April 2005 at 16:21
    My point was some clients not knowing what they are doing and sending in PDF as bitmaps even after explaining what you require to work from.
    I understand why you save as bitmap & low res.
    Why dont you just set security on the PDF John to allow viewing on screen only? Just curious.
    Tim.
  • Rodney Gold
    19 April 2005 at 16:30
    PDF imports directly into Corel 11 , if it is vector , it will remain vector , raster will be raster and it might be mixed and be both. Problem will be fonts – if your puter doesnt have a referenced font it will subsitute.
    Once in Corel , you can manipulate as you like.
  • Dave Ward
    19 April 2005 at 18:24
    i have the full version of adobe acrobat 7 so If you email me the pdf file i will export as eps and email it back to you if that will work ?
    signshop@fsmail.net
  • Frank Droog
    19 April 2005 at 18:52
    The new Signlab pdf import filter, gives you the option to bring in text as text, or text as graphics.
    In either case, it tries to use the correct shape of the letters.
    Fonts in Pdf , and others like ai/eps, can either be embedded in the pdf file, or be a referance to an external font.
    The import filter will use the glyphs from either embedded or external fonts. So in theory, the only problem will be a referance to a external font that is not on your system. Then signlab will ask you to substitute the font.
    Embedded fonts should allways be correct.
    However, they are still some issues with multi byte foreign characher fonts if that the correct terminology.
    Finaly, while there is the concept of Text in AI/EPS/PDF, there is no concept of Begin Paragraph / End paragragh. The new import filters tries as much as possible to bring multilple lines of text in as a paragraph instead of each line or bit of text it finds, as a seperate Paragraph.
    It works pretty well in buiding up paragraphs.This is usefull when importing 100+ page PDF manuals instead of 1 page graphics.
    frank at cadlink
    19 April 2005 at 19:51
    i import the same as rodney into corel draw 11…i just found this out a couple of weeks ago by accident 😳 works a treat!! 😀
  • asifnmalik
    1 May 2005 at 16:07
    I agree with nik, corel is one of the best pieces of software for PDF reading and creation. Just make sure that when the customer saves the PDF that they convert the text to curves.
  • John & Dawn Roddick
    6 May 2005 at 20:44
    We have Corel Draw 9 – does this have the facility to import PDFs?
    I can copy to the clipboard and paste from there but I then have to trace it and a lot of the clarity is lost.
    7 May 2005 at 09:11
    Corel 9 is a bit concerning for importing PDF’s or I cant remember.
    Corel 10 does it
    Corel 11 Is okay and has about 70% success factor
    Corel 12 will open the Acrobat 6 format and the newer Illustrator native (PDF format)
    Adobe Acrobat Professional comes in handy converting to PDF>EPS and that can make it much easy to transfer to Corel (Postscript Import filter)
