Home Forums Software Discussions Corel Software Can A Fill Be Made Cuttable?
  • Can A Fill Be Made Cuttable?
    Posted by Paul Humble on 14 February 2009 at 13:24
    Ive got a graphic in Corel X3 that I have filled with circles (dont ask), is there any easy way to make these circles cuttable as my cutter doesnt see them.
    Alan Drury replied 16 years, 10 months ago 4 Members · 6 Replies
  • Harry Cleary
    14 February 2009 at 13:33
    do the circles have hairline outlines Paul? SHould cut if they have or maybe i am not understanding you.
  • Paul Humble
    14 February 2009 at 13:36
    No Harry, ive basically just filled the shape I need (a rectangle) with circles using the fill tool on Corel so they have no outlines. Im just wondering if there is a way to get them with outlines other than me having to do each circle individually.
  • Harry Cleary
    14 February 2009 at 13:41
    Have you tried ‘select all’ and then outline?
  • Jason Davies
    14 February 2009 at 13:44
    You’ve completed what we used to call a postscript fill I think, the only way to cut these is to draw them/duplicate and then use your pathfinder tool to merge the lines so the cutter will cut them properly, apologies for the ‘Illustrator’ terminology but the same principle.
    Jason
  • Paul Humble
    14 February 2009 at 13:57
    Sorted it now by converting to Bitmap then tracing it. Not sure if this is the right way but its done the trick.
    14 February 2009 at 14:18
    If postscript fill – print to ‘device independent postscript file’ This creates a postscript file, file extension is .ps and can be printed to any folder you choose. Import this ps file using eps filter (ps filter in X4) using editable filter if offered.
    Editable curves will now be displayed, please note any outlines may need changing to object and welding, depending on number of objects it maybe worth doing these in bits rather a complete unit as welding very large number of objects may choke the system.
    Alan D
