Home Forums Sign Making Discussions General Sign Topics Cable sign display issue
  • Cable sign display issue
    Posted by Rachel on 28 September 2005 at 09:46
    Hi can anyone help me?
    I have a customer who has a restaurant and wishes to display his menus outside on cables. The problem I have is that he wishes to make a feature of these cables looking to have them 8-10mm thick connected to D-rings top and bottom. I can only find display systems with 1.5/3mm thick cables. As they are outside they will also need to be stainless steel.
    Would anyone know a supplier that can help me out?
    Rachel
    southernandy replied 20 years, 3 months ago 4 Members · 4 Replies
  • Simon Clayton
    28 September 2005 at 09:49
    Could try these people, http://www.southernrigging.co.uk/
    Simon
  • Signs & Wonders
    28 September 2005 at 09:53
    Rachel
    Just a thought, but what about using 10mm threaded bar. All sorts of fixings available and a ‘similar’ look to steel cables. Obviously depends on the effect you are trying to achieve.
    Tony
  • Chris Hooper
    28 September 2005 at 10:45
    try mid west displays Tel: 01743 248095 Know for a fact they do 6mm cable or rod not sure about 10mm.
  • southernandy
    28 September 2005 at 11:53
    I’d go with Simons option.
    You really want a heavy duty stainless steel type effort- standard rod or cable displays will last about 5 minutes outside- they will be decorating the local chav homestead just as you drive off round the corner.
    Some chunky braided cable onto some D links would be better- long screws and bolts.
