Home Forums Sign Making Discussions CNC Router and Engraving Brass Sheet Grades and Types for Engraving
  • Brass Sheet Grades and Types for Engraving
    Posted by Darrell Wootton on 14 October 2009 at 09:52
    We are looking to source some brass sheet for engraving.
    We have found a supplier of Engravers Brass Sheet 2mm and 3mm (Grade CZ120 Hard) from Rightons, but are wondering if any other grade of brass is suitable in thinner sizes, polished etc etc?
    Thanks in advance
    Daz…….
    Andrew Blackett replied 16 years, 2 months ago 4 Members · 4 Replies
  • Simon Strom
    14 October 2009 at 18:52
    Hi Darrell,
    I don’t deal with making the plaques directly. We order ours out. We usually use Gemini (US company). Anyway, I’ll just list what they use for engraving. Might have company to source from close to you. It’s possible that these alloys differ from what’s sold in your area. Maybe someone else on the boards here can answer better.
    These are listed for etching:
    Stainless Steel:
    Alloy 304; Optional Alloy 316
    1/16", 1/8", 3/16" & 1/4" Depths
    Commercial Bronze: (90/10)
    Alloy C22000; 90% Copper / 10% Zinc
    1/16", 1/8", 3/16", 1/4" & 5/16" Depths
    Naval Brass (60/39/1) Muntz (60/40)
    Alloy C46400 (Muntz Equivalent);
    60% Copper / 39.25% Zinc / .75% Tin
    Copper:
    Alloy C11000
  • Graeme Harrold
    14 October 2009 at 19:00
    Half hard or engravers brass is what you need, get it wrong and you’ll end up with ragged cuts and dull cutters. Play it safe and order in from the likes of Mastergrave, Suregrave, Gravograph or Pantograph services………Once you get above 1.5mm tredle guillotine cutting gets difficult and you’ll either have to use a power shear or disc cutter.
    Its rare you will need to go above 1.5mm, above suppliers will also cut to size usually free……….
  • Darrell Wootton
    14 October 2009 at 19:56
    Thank you both for the information, I will do a bit more research bearing in mind both your guidelines and suggestions.
    Daz……
  • Andrew Blackett
    14 October 2009 at 21:02
    Daz,
    Ring Zoe at engravamet mate, they are always competitive. and as already mentioned stick to CZ120 hard tempered mate – it’ll cut and machine the best.
    Top of my head but I think 1.5mm thick bright polished one side is running out at about £75 for a 4×2 sheet.
    Andy
