Home Forums Sign Making Discussions General Sign Topics Bottom Loading Alupanel into Slimtrim
  • Bottom Loading Alupanel into Slimtrim
    Posted by Aaron & Chris on 23 February 2005 at 11:21
    Hi everyone
    We have been asked to do a shop front sign thats 2500mm x 500mm. We are going to be using Slimtrim from Amari Plastics and Alupanel thats 3mm thick and all this will be backed onto a plywood surface. The problem is that we cant load the sign from the sides or the top due to obstructions that cant be avoided. 😕
    So my question is can we load the sign from the bottom? (?)
    Any help or suggestions very welcome!! 😀
    Chris
    Guy Burt-Davies replied 20 years, 10 months ago 4 Members · 4 Replies
  • Simon Clayton
    23 February 2005 at 14:17
    Not sure on that, but you could use unitrim from universal, it basically has removable trim like an illuminated box.. When they do the frame make sure you tell them its for 3mm panels, also put in some spacers in the bottom just to lift the panel up a bit, this will help stop the water traveling up the panel and leaving green moldy marks
    Simon
  • Aaron & Chris
    23 February 2005 at 16:08
    Cheers Simon we have asked for some info on it from universal.
    Any other suggestions welcome
    Chris 😀
  • Fred Caffrey
    23 February 2005 at 18:41
    Hi, you could try the dibond frame as seen in the SignUpdate ad page 65 Jan/ Feb issue, or http://www.insightsignsystems.com.
    Fred
  • Guy Burt-Davies
    23 February 2005 at 18:57
    We’ve just installed 30 of the Dibond panels from Insight and found it was easier than making our own!
