• board cutter
    Posted by Chris Windebank on 3 December 2009 at 15:30
    Hi all, there was a board cutter at the sign sign earlier this year that was good on cost and if I remember correctly folded away, ring any bells with anyone? Sorry for being so vague
    Lorraine Clinch replied 16 years ago 7 Members · 16 Replies
  • 16 Replies
    3 December 2009 at 15:34
    I think it was the Zapkut
    http://www.zapkut.co.uk/index.htm
  • Tim Painter
    3 December 2009 at 15:36
    Maybe the one also sold on Flea-Bay I forget what it’s called sorry.
  • Chris Windebank
    3 December 2009 at 20:01
    thanks guys, brought the keen cut today instead after some research, hope I made the right choice
  • Warren Beard
    3 December 2009 at 20:09
    Which one did you get Chris and let me know how you get on with it as it is something I have been thinking about for a while.
    Warren
  • Chris Windebank
    4 December 2009 at 08:11
    Got it from Jag sign supplies in the end
  • Warren Beard
    4 December 2009 at 10:19
    HI Chris
    They have a few Keen Cut ones so was wondering which you got?
  • Chris Windebank
    4 December 2009 at 10:27
    went for the evolution which fits to the bench, also can fit in van as its 1.6m
    There are some vids on the Keencut website
  • Vic Adair
    4 December 2009 at 10:53
    Anyone tried the one from JML, little cross between a circular saw and jig saw?….. uses a small fine circular blade.
    Seen this advertised in some shop, looks as if you could use it like knife with a straight edge. They come about £90
    Thought it would be a handy wee tool to have for quick jobs!! 🙂
  • Chris Windebank
    4 December 2009 at 11:57
    The Exakt saw you are on about is for cutting laminate flooring. It is a great tool and cuts dibond with ease but like every saw, it spews out loads of debris although it does come with an extraction hose
  • Vic Adair
    4 December 2009 at 12:22
    quote Chris Windebank:
    Hi Chris,
    Yeah thats the one.
    Do you have one and is it worth the money.
    Was thinking of adding it to my xmas list but wasn’t sure if it was sturdy enough for doing Dibond.
    Also, will it cut foam and if so to what depth?
  • Lorraine Clinch
    4 December 2009 at 12:34
    Hi Vic
    I have had an Exactkut for several years, only gets used for cutting composite that wont fit through the Excalibur, but is great for doing the job. As Chris said, it creates loads of debris, I always use it outside, or there would be bits of plastic everywhere. (Clean the boards off too, swarf clings to them!)
    Lorraine
  • Vic Adair
    4 December 2009 at 13:46
    Lorraine hi,
    Just been watching a video on youtube about the saw, looks quite good!
    They had a hose attachment to it and using a vac
    Which blade would be best for cutting Dibond and where would you get replacements?
    Vic
    4 December 2009 at 14:02
    my problem with my Exakt saw is following the straight edge, the dust collector works well but gets in the way.
    so it don’t get used much, shame as its a nice tool we just can’t get the best out of it.
    have a practice with it now and again but no confidence on 4ft + cuts, i am sure the tool is fine just numpty operators.
  • Vic Adair
    4 December 2009 at 15:22
    quote Chris Wool:
    The guy doing the video on you-tube used a hose connected with a clip and attached to a hoover, the hose was taped to the Elec. cord to keep neat.
    Does the saw come with a collector bag??
    4 December 2009 at 15:35
    hose to hover works well no mess but it gets in the way no matter what you do with it. bag with out suck would be no good.
  • Lorraine Clinch
    4 December 2009 at 16:30
    That’s why we use the saw outside, rarely use the hose as it gets in the way.
    Chris, I agree it is difficult to get a good long straight cut, this is due to having to keep the pressure on (for the depth) whilst changing position .
    So yes, good, small saw, still has it’s drawbacks though.
    Nothings perfect I guess.
    Lorraine
