Home Forums Software Discussions General Software Topics bmp to cuttable vector?
  • bmp to cuttable vector?
    Posted by Darryl Seager on 14 March 2005 at 22:53
    Hi Team,
    i would like to know how to convert a bmp. into a cuttable vector.
    I think i have used the correct terminolgy , but if not……
    i want to take a bitmap/ jpeg and create a simple cuttable image. the images i have in mind would be excavators and plant type machinery. the result does not need to be incredibly detailed,rather more..recogniseable than precision vectors as per the Vectorwise type…
    Can anyone offer any advise/pointers?
    Darryl
    Darryl Seager replied 20 years, 8 months ago 4 Members · 6 Replies
    14 March 2005 at 23:10
    You need software that can trace the image into a cuttable vector. The cheapest option is Corel draw which has a feature called “Corel Trace” but better to use a dedicated sign software program such as Signlab (which has an extremely effective vectorisation tool), or Casmate, flexisign and most other dedicated sign software programs.
  • John Childs
    14 March 2005 at 23:23
    There’s Adobe Streamline as well.
  • Darryl Seager
    15 March 2005 at 20:27
    Thanks guys,
    i must play with the settings more, and try out all the options.
    i use flexi’ anyway and knew about its trace tools, Corel i am a recent convert to and had tried one or two of its options. for what i want to achieve will take a lot of practise i think, and it will mean manually drawing i think.
    I’ll see if i can remember to bring some piccies home, or find time to post wednesday at work of what i want to finish up with.
    regards
    Darryl
  • curt
    21 March 2005 at 00:57
    Its not always just a matter of tracing some bitmaps. There are a few techniques that will make your job easier.
    In Corel draw…from the menu bar.. Bitmap/ mode /blackandwhite 1 bit. This gives the tracing proggy something easier to look at. While there select “line art” and then adjust the thresh hold to make it optimum.
    Now your bitmap is black and white. Select the bitmap by Lclick on it. Then from the menu bar in corel,, bitmap/tracebitmap which opens corel trace.
    Then do your trace.. You have several selections there. Try outline or advanced outline to see what gives you a good trace.
    When done close corel trace and it will save it back to coreldraw for you.
    This is not an all inclusive how to. But it will get a novice into the arena for getting a much better trace.
    curt
  • John Childs
    21 March 2005 at 08:01
    I was thinking about this last week.
    I bought Adobe Streamline in about 1989 and it was an essential tool which got used all the time, if not every day, then certainly several times a week. I couldn’t have worked without it.
    This thread made me wonder because I realised that I can’t remember the last time I used it and I don’t know why that is. Maybe we are getting more vector files from our clients so that they can avoid paying the charge or maybe as my vectorising skills have got better so I am more inclined to do it manually. Maybe it’s just the type of work I do.
    Whatever, although it can still be a useful tool, it is certainly not as important as it used to be.
  • Darryl Seager
    21 March 2005 at 08:11
    Thanks for that Curt, i’ll give it a try using your directions
    Apparently Streamline is still in the market place John.
    Darryl
