Home › Forums › Printing Discussions › General Printing Topics › blueback paper
blueback paper
Posted by MikeeWalsh on 4 February 2008 at 17:42i have a versacamm and was wondering what the quality of printing on bluback paper is like?
Steve McAdie replied 17 years, 11 months ago 4 Members · 11 Replies -
hi Mike
just run a poster through on my cadet plus blue back matt paper
eco sol max inksi just use a generic vinyl profile and it is ok takes a bit to dry but apart from that looks ok
had a look at a blue backpaper profile but the colours looked realy weak on screen will have to print a sample to see what it looks like.
the old story never enough timewhat are you going to print on it
derek -
we produce glass reinforced plastic panels that have digital prints encapsulated inside. we currently plastic encapsulate our prints as the ink runs when we apply our resin. I thought the blue back paper might absorb the inks more and hold it to the paper.
mike what paper are you using at the moment. and what is the finished product please.
i use uniform satin matt paper but as we apply our resin the ink lifts off even after we have left the prints to dry for a week. our finished product is glass reinforced plastic panel
is this with polyester or epoxy resins, have you tried the photo grade resin backed papers.
I’m not sure. we used to get our prints from a supplier and have only recently bought a versacamm so i am still experimenting with paper types. we get our paper from silverskies
sorry that made me look quite dumb. haha they are polyester resins
i would expect (dont know for sure) that the problem is the resin attacking the inks.
epoxy resins will not attack the ink. well i would not expect them to
however you could laminate the prints before applying either resin but if flexed may de-laminate or use a matt typestill want to know the finished product please
had a thought last night, if you printed with a epson or hp – cannon with pigmented inks the inks are not solvent based then polyester resin should be ok.
I used to do GRP encapsulated prints some years ago for a sign firm i worked for they used to use paper which they had to have printed elsewhere but the problem with that was if scratched deep enough water would ingress and quickly the print would deteriorate. I would put money on it that its the polyester resin causing the solvent print to dissolve also you may find that the resin could attack a laminate. What the firm did was buy a durachrome thermal printer as this is resistant to polyester resin.
