Home Forums Printing Discussions Roland Printers Blends gone wrong…..
  • Blends gone wrong…..
    Posted by Philip Houston on 17 April 2014 at 11:26
    Hi sign people!
    Todays problem…..
    Using Flexi 7.5 on my imac.
    Create a blend image from red to yellow.
    File saved as eps and opened in versaworks.
    When printed, the image is a good red blending into fine line of yellow which then turns into a lime green.
    Experimented with different blends of red & yellow but same result.
    Any suggestions?
    Philip
    NeilFox replied 11 years, 7 months ago 4 Members · 6 Replies
  • NeilFox
    18 April 2014 at 08:49
    Do you have another design package, Illustrator or Corel? If so, create a new file with the colour colour mode set to CMYK. Create a blend, then save as an eps and add it to the VersaWorks queue and print it.
    See if the result change at all.
    I had a lot of trouble getting good reds particularly in both Flexi and Signlab, so for anything printed I now use Illustrator and make sure the colour mode is CMYK and it seems to work pretty well for me.
  • John Harding
    18 April 2014 at 09:07
    dont think its the blend just the output colour of the yellow, straight from flexi to my roland would give similar results so I always import eps to signlab and set rvw colours before printing just work out whatver works for your setup
    John 😀
  • Kevin Flowers
    18 April 2014 at 16:41
    make a 100% yellow colour chip in your colour palette and then select it when you create the gradient make sure you select cmyk
  • Kevin Flowers
    18 April 2014 at 16:43
    quote John Harding:
    John 😀
    John why do you not import the Roland palette into Flexi
  • Philip Houston
    23 April 2014 at 09:11
    Hi Kevin,
    you’re the new "UK Signboards Superhero of the Day"!!
    Turned the blend into cmyk in flexi and it’s printing PERFECT.
    Thank you for your help.
    Philip
  • NeilFox
    23 April 2014 at 17:56
    I have had the same issue when the artwork from Illustrator was RGB. Need to have a CMYK workspace / artboard.
    Good to hear its sorted.
