Home › Forums › Vinyl Cutter Discussions › General Cutter topics › blades – how long does yours last?
Posted by JOHN BEEDHAM on 3 April 2006 at 04:21how often does the average person go through genuin needle blades
and none geniun blades ? (roland)
i seem to use one every 4 weeks.Shane Drew replied 19 years, 9 months ago 2 Members · 9 Replies -
John, I get a few months out of mine.
I use one for normal material, and one for reflective.
You may have the blade pressure to deep from the start.
When it is new, I do some sample cuts with the new blade at the lowest pressure I can, but still weed ok.
Cast material (7725,751,avery900) will need less pressure than a cal material. The cheaper the cal, the more pressure usually.
What Roland do you have? On my Camm1 1000mm wide, I usually start with a new blade on 70 on the pressure guide, and over time, add 5 every few weeks. I don’t usually replace the blade until I am up around 120 or so, or the material is not cutting or weeding properly.
Use a 40deg blade on normal material, and a 60deg blade on reflective, as a rule of thumb.
Hope that helps mate.
it certainly does mate…..i use multifix cal.
and it is really thick like cardboard.
thanks again buddy.
ps.my roland is a camm1 pnc 900. -
quote JOHN BEEDHAM:it certainly does mate…..i use multifix cal.
thanks again buddy.
ps.my roland is a camm1 pnc 900.John, try Oracal 551 or 651 series. Excellent stuff to cut and weed.
I’ll send you a sample of the 551 if you want to try it. Let me know what your trading name is and I’ll post you some.
HEY shane…..how are ya.
My trading name is doctor sticker.
Am i aloud to put my adress up on here.
or is it a no no.john.
Redcliffe…….or more exactly,…kippa-ring
john.
PS. if you have a return address on the parcel i will send you some multifix.
:lol1:
😮 I was looking in the phone book and found a beedham in Kippa Ring but Defender Ave. Any relation?
I’ll get some away tomorrow on a courier.
Shane -
No worries John. I’ll get onto Oracal in the morning and see if I can get you a colour card as well.
I’ll get them to post it to you directly.
Cheers mate
