Home Forums Printing Discussions Roland Printers Blade holder mechanism bouncing – help please?
  • Blade holder mechanism bouncing – help please?
    Posted by Warren Beard on 29 July 2015 at 13:59
    Our Roland XR640 has just started giving us problems with cutting, the blade holder should stay sprung up against the top of the carriage (like on a stiff spring holding it up) however it keeps dropping down and "bouncing" as though on a soft spring and sitting half way down and seems to bounce when going through the cutting motions.
    Sometimes it’s fine and then half way through cutting or at any random time it goes loose and cuts erratically.
    Anybody have any ideas and also if anybody can recommend an engineer in the Hampshire area that would be great.
    Stafford Cox replied 10 years, 4 months ago 4 Members · 9 Replies
  • 9 Replies
  • Kevin Flowers
    29 July 2015 at 16:31
    Warren
    hope you are well mate, sounds like you may have a break in a cable, i know your machine isn’t mega old but there seems no rhyme or reason as to when these go it depends how they lay back down as the carriage moves. You could check connection plus haven’t worked loose
  • Denise Goodfellow
    29 July 2015 at 17:43
    Many years ago we had a similar problem with a Roland cutter, it turned out to be a solenoid in the blade holding unit
  • Warren Beard
    30 July 2015 at 08:15
    Thanks Kevin and Denise, will look forther in to it before calling in engineers.
    Warren
  • Warren Beard
    30 July 2015 at 13:27
    Well taking a closer look I don’t know what the black dust is from from something’s rubbing and wearing something down. I think it may be this dirt on the strip causing issues?
    What can I clean it with? is IPA OK to use on it?
    Thanks Warren
  • Stafford Cox
    31 July 2015 at 15:40
    IPA should be OK, but don’t use anything any more aggressive like head cleaning solution.
    As Kev says though, I would probably look at the cut cable and guide. They’re pretty inexpensive to buy.
    Stafford
  • Warren Beard
    5 August 2015 at 15:07
    Update: it was a cracked cable which has now been replaced and working good as new again. Surprised it didn’t last that long, cheap part but 4 hours to replace by an engineer isn’t cheap that’s for sure 😉
    Thanks for your replies, much appreciated.
    Warren
  • Stafford Cox
    5 August 2015 at 15:19
    4 hours!!??
    Seems a bit excessive to replace the cable and guide, but maybe there was some other service work done at the same time. Did you get Roland to do it?
    Stafford
  • Warren Beard
    5 August 2015 at 18:56
    Printmax, I suppose maybe about 3hrs as we did spend some time asking other questions etc and he checked one or 2 setting.
  • Stafford Cox
    5 August 2015 at 19:49
    Fair enough. As long as it’s up and running again, that’s the main thing.
