Home Forums Printing Discussions Printer Ink Black ink going into my magenta damper and cyan into yellow
  • Black ink going into my magenta damper and cyan into yellow
    Posted by Alieu Cham on 15 August 2012 at 05:45
    Hello All….. can someone please help me …..
    my machine is mimaki jv3 160s with 6 colours
    this machine had 3 heads together which joins
    black and magenta 1 head
    cyan and yellow 2 head
    lc and lm 3 head
    looking at this set up(above)…… the problem am having is that
    in head 1 when i test print or send print the result of the printing will be black because the black ink goes into the magenta damper….
    and same effect into the yellow damper having cyan ink.
    can anyone help to solved this problem….
    also if anyone can help with drawing diagrams which damper should goes where into the heads setting hope am not crossing the setting …
    thanks all in advances…
    regards
    Alieu Cham
    from the Gambia
    David Rowland replied 13 years, 4 months ago 2 Members · 3 Replies
  • Stafford Cox
    22 August 2012 at 08:12
    More than likey you have a pump(s) that is not clearing out properly. Try running a Disway wash. The liquid should stay in the cap until you hear the pumps clicking then it should drain away quite quickly.
    Stafford
    22 August 2012 at 11:56
    http://www.uksignboards.com/viewtopic.php?t=55781
    duplicate posts
    I see asked for my help direct… best just to post here
    22 August 2012 at 11:59
    The colour order is
    BLACK – MAGENTA – CYAN – YELLOW – Light Magenta – Light Cyan
