Best way to produce shadowed vinyl?
What would be the best way to produce large vinyl text (imagine uksignboards.com as the text) in white with a black cast shadow.
This is to go on coaches which will get plenty of grime & cleaning.
Options are:
1/ White vinyl overlaid on black vinyl. Comment:Twice the work & material, time consuming & difficult to line up.
2/ White vinyl with printed shadow (print/laminate/contour cut). Comment: probably the most durable and the correct way.
3/ White vinyl with printed shadow (contour cut then liquid laminate over whole of text). Comment: cheaper than vinyl laminate & quicker to produce but less durable than 2.
Each vehicle would use around 8 metres of printed vinyl.
The fleet would use around 160 metres so I need to go about it the right way.
