Home Forums Sign Making Discussions General Sign Topics best way to power a heat gun if you have no mains supply?
  • Jason Xuereb
    6 February 2008 at 13:09
    blow torches 😛
  • Stuart Hancock
    6 February 2008 at 13:16
    Just get yourself a portable generator.
    http://www.justgenerators.co.uk/pages/p … rators.htm
  • Gary Birch
    6 February 2008 at 13:49
    I`d go the generator too. I got one off ebay which is more than up to the job.
    Just a tad heavy if i`m on my own.
    Gary
  • MikeeWalsh
    6 February 2008 at 14:03
    is there no way you could run it through the cigarette lighter
  • Gary Birch
    6 February 2008 at 14:27
    I`m no expert but I don`t think so.
    Gary
    6 February 2008 at 14:35
    i have a dewalt 2000w heat gun, when i did a mobi mechanics van, he said to plug it into his 1500w generator, the thing nearly pooped itself and the gun barely got warm, so… be prepared t fork out for a good 2.5kw generator, not a cheapy on.
    a ciggy lighter wouldn’t run it! if you could get a 12v gun, i think you’d find that it’ll either not get hot enough, or will kill the battery in no time.
    i have a heavy duty 50m extention lead. it can usually find power!
  • Nick Minall
    6 February 2008 at 14:36
    Well you can get 3000 w inverters, not sure what amps they would need on the 12v side.
  • David Rogers
    6 February 2008 at 15:06
    quote Nick Minall:
    enough to melt your car’s wiring… (hot)
    Watts = Amps x Volts…..Amps = Watts / Volts
  • MikeeWalsh
    6 February 2008 at 15:13
    ok i think the 50m extension lead looks the best idea thanks for that
    6 February 2008 at 15:21
    tell the customer that price has just doubled.
    should then be enough hot air to do the job 😉
  • Gary Birch
    6 February 2008 at 15:27
    I paid £80 for a NUTOOL 2.4KW generator. Not the best make but good enough for the use it gets from us. I wouldn`t be without it now.
    I know Macro have similar deals occasionally.
    Gary
  • Nick Monir
    6 February 2008 at 22:00
    Mike I’d go with a genny too. I bought one a few years ago for less than £200 and I couldn’t live without it. Great for heatguns, SDS drills, charging batteries, floodlights etc etc. Its got 110 and 240v. Paid for itself over and over.
    Nick
  • Mathew Gibson
    7 February 2008 at 08:49
    Please tell me if i am wrong but cant you buy cordless ones im sure ive seen them being used at the show last year?
  • James Martin
    18 February 2008 at 23:21
    I was speaking to an auto-electrician today and he said he could rig an inverter in my 1.7 corsa diesel that you could run a snack bar from lol.
    He said, "a heat gun"? No problem.
    18 February 2008 at 23:23
    so James when does the snack bar start 😀 you can sign it your self
  • James Martin
    18 February 2008 at 23:35
    Hey am trying to loose a couple of pounds, a snack bar would be a bad move.
    18 February 2008 at 23:38
    quote James Martin:
    He said, “a heat gun”? No problem.
    James, its possible to run an arc welder from a small engine, the alternator is replaced with a larger unit, but the total output cannot be greater than the power available at the pulley that drives the unit.
    what it means in layman’s terms is you cant get out more than you put in.
  • Brian Little
    19 February 2008 at 09:05
    quote mikeewalsh:
    hmmm i heard it said once from an electrician ….dont know if its true or not that you can actually damage equipment if you have to long an extension leed ….not that bursting a heat gun is the end of the world just a thought
  • James Martin
    20 February 2008 at 10:44
    Hi Peter,
    I think I understand.
    Does that mean that its not the full power of the engine recharging the battery at idling speed?
