Home Forums Sign Making Discussions Vinyl best way to apply contravision
  • best way to apply contravision
    Posted by Phil McGovern on 22 October 2008 at 06:54
    Hi all, i am being asked to fit contavision for another company onto some bus windows in 2 sections at 3m each . its apparently metamark 1-2 yr which has been laminated. as i have never fitted contavision before i’m after your expert advice 😀
    Is it better applied dry ? is there anything i need to be careful of with it having small holes in it ?
    Phil
    Gavin MacMillan replied 17 years, 1 month ago 6 Members · 18 Replies
  • 18 Replies
    22 October 2008 at 07:18
    i would say "completely bone dry" no moisture at all…
    clean the windows with meths, isoprop or the like and make sure the windows are degreased.
    you shouldnt have issues with initial tack as there is little initial tack with this stuff due to the holes. (try a spare bit on your office window to get a feel for it)
    water will trap in the holes and be sealed due to the lamination and it will be impossible to squeegee any residue out.
    i would also trim it a mm or two back from the rubber window moulding because this stuff has a tendency to lift after an hour or so if not completely flat. if it does lift it can cause bother because it does not like to go back down due to the low tack.
    i am guessing but in this cold weather ide advise fitting indoors and a gentle heat with a heat gun to help adhesion. (not too much in one spot though incase you crack glass, not that i have heard of it on a vehicle but definitely seen it happen on a window)
    22 October 2008 at 07:32
    I agree with Rob, definitely dry.
    Only thing I do is run a 12mm edge of clear around the outside of the print/window so it doesn’t lift with moisture later.
    Being laminated, you’ll end up with half moons on the edges which will fill with water, and eventually lift the edge
  • Jason Xuereb
    22 October 2008 at 07:58
    Don’t use a heat gun you will stretch the film and cause the circles to turn in ovals and it looks distorted from the inside of the window.
    22 October 2008 at 08:09
    quote Jason Xuereb:
    I use a heat gun, but very carefully, some of the spears on a curved back window can be more trouble then they are worth. Need a bit of heat to encourage them to stay down 🙂
  • Jason Xuereb
    22 October 2008 at 08:10
    I just use pressure 🙂
  • Phil McGovern
    22 October 2008 at 17:37
    Cheers Guys, ill get on with it then thanks for the advice
    22 October 2008 at 20:02
    better by far, print onto your choice of white digital, then cut into strips like 2mm gap, 5mm stripe on your cutter, better job and cheaper,
    22 October 2008 at 22:11
    quote Peter Normington:
    we have a shop do that here, and I use it as a selling point for one way vision.
    If the client uses the rear wiper a lot (and they usually do even though you ask them not to), one of the stripes can lift eventually, and then its missing bits…. a few cars floating around my area with that look now, so when you mention it, people say ‘oh, I’ve seen that… looks horrible’. I get the one way vision job every time…. but I’m a fair bit dearer as you say.
    Real beauty is that I don’t talk ill of the other shop, but their reputation is tainted as a result of pointing out who did it.
  • Jason Xuereb
    22 October 2008 at 23:38
    What if they laminated it with optically clear? Then its not going to lift.
    23 October 2008 at 01:34
    quote Jason Xuereb:
    yes it is… half moon problem still applies. I do all my stuff in optically clear. Still edge it. My opposition don’t edge, and they have problems galore.
    That is why I started doing it in truth.
  • Jason Xuereb
    23 October 2008 at 03:19
    I edge seal all my laminated installs.
    I don’t edge seal non laminated ones.
    23 October 2008 at 05:14
    quote Jason Xuereb:
    So you do edge optically clear laminated owv then? I’m confused….
    I don’t edge seal non laminated either
  • Jason Xuereb
    23 October 2008 at 06:55
    Hey Shane,
    If the one way vision is laminated I use a strip of laminate to seal all the edges.
    If the print is un laminated I don’t do this.
    Hope that’s clear.
  • Gavin MacMillan
    23 October 2008 at 06:57
    I think Jason was saying you could laminate the striped version with optically clear to save it lifting. This would be fine but I still prefer the look of one-way to the gapped version.
    Why do you lamninate one way at all? It’s a fairly short term film and the gaps are too small to allow the lam to adhere to the glass so it will go funny over time. I suppose a liquid laminate would make sense but only to stop abrasion as the film is way shorter term than the inks or maybe I’m missing something?
    G
  • Jason Xuereb
    23 October 2008 at 07:01
    Gavin,
    Have you driven a car in the rain without laminate? Can’t see a thing.
  • Gavin MacMillan
    23 October 2008 at 07:05
    will the same thing not happen to laminate over time? If it’s not touching the glass it’ll corrode?
  • Jason Xuereb
    23 October 2008 at 07:13
    Not if the install is properly sealed along the edges. The laminate is optically clear and you can see through. If you don’t seal it properly what will happen is moisture etc will get in under the laminate and kind of fog up the window.
    that’s even worse then rain. I learnt the hard way lucky it was on our vehicle.
  • Gavin MacMillan
    23 October 2008 at 07:42
    I’ve only got one vehicle done that this would be an issue on, it’s un-laminated and it’s pi**ing down here so I’ll go and have a look at it. Certainly had no feedback from the customer (other than loving the job when first done) but that doesn’t mean much
