Home Forums Sign Making Discussions General Sign Topics Best materials for butchers blackboards?
  • Best materials for butchers blackboards?
    Posted by Peter Dee on 30 June 2008 at 07:22
    I have been asked for some wall mounted blackboards in a butchers shop.
    They want some permanent vinyl graphics on it plus the ability to use chalkboard markers for special offers etc.
    I’m looking for ideas & suggestions as to what materials to make these from.
    Peter Dee replied 17 years, 6 months ago 5 Members · 9 Replies
  • 9 Replies
  • Gavin MacMillan
    30 June 2008 at 07:34
    You could use chalk board vinyl from doro or hexis and apply to whatever substrate best suits, this takes vinyl lettering just fine.
    G
  • Steve Morgan
    30 June 2008 at 07:35
    Peter,
    I’ve used a laminate, as in formica type material, bonded onto 9mm mdf/chipboard/good quality plywood. The material is very flat and works well with chalk pens but less so with ordinary chalk, unless the chalk is a bit damp.
    I used to buy from Robert Horne, sheet size 1220 x 2440
  • Peter Dee
    30 June 2008 at 09:11
    Thanks guys, I’ll look in to those ideas.
  • Mick Folan
    1 July 2008 at 17:17
    The last butcher shop we fitted out had to have white boards and markers because the HSE in their infinite wisdom think blackboards and chalks are unhygienic.
  • Peter Dee
    1 July 2008 at 17:33
    Yes I’m fending off the chalk idea in favour of the blackboard vinyl which Gavin mentioned.
  • Steve Morgan
    1 July 2008 at 17:58
    Peter,
    I tried the chalk board vinyl, and with chalk pens particularly, it was not nearly as good. The hard surface of the laminate was far superior.
  • Peter Dee
    2 July 2008 at 07:13
    Thanks Steve. What is the laminate actually called?
    2 July 2008 at 08:14
    you can buy chalk board vinyl and dry wipe vinyl from Metamark.
    I bought some recently. we had staffing boards to make that had to have a section that could be written on amongst some permanent text, logos etc so we had a section covered in dry wipe vinyl and bought a pack of assorted colours of dry wipe markers from WH Smith i think… worked a treat…
  • Peter Dee
    2 July 2008 at 08:40
    Cheers Rob
