• best material?
    Posted by Tris Gee on 24 June 2007 at 19:55
    hi all.
    im after sourcing the best material for a vinyl written sign to go on a painted brick wall of a shop . ive heard of foam x, and correx. i dont like look of correx, or maybe its just the signs ive seen made with it . ive seen the mention of diabond?? i need it to look good, but without blowing the bank, could some one pls advise me on best , reasonable priced material. thanks
    forgot to mention its an exterior sign
    Tris Gee replied 18 years, 6 months ago 5 Members · 10 Replies
  • 10 Replies
  • Richard Urquhart
    24 June 2007 at 19:59
    Hi mate di-bond would be best and costs about £80 for a 10x 5
    foam-ex is rubbish as it will warp and bow with heat and cold however its only about £20 a sheet
    before its goes in to a debate there are good uses for foam-ex
  • Tris Gee
    24 June 2007 at 20:22
    hi, is diabond like a fibre glass sheet and smoothed on the application side, or am i thinking of something else?
  • Richard Urquhart
    24 June 2007 at 20:30
    Di-Bond is made up as follows 2 sheets of thin ali with a plastic core
  • Tris Gee
    24 June 2007 at 20:37
    oh great, ill look it getting some of that, and is it easy enough to cut and shape yourself?
    24 June 2007 at 21:09
    europoint do an alternative dibond type composite board called "leboard" costs about £40 for an 8×4 only comes in white and silver, but if your good at flood coating in vinyl its a good alternative.
    24 June 2007 at 21:15
    I wouldn’t dismiss fomex out of hand if used correctly and fitted properly it is a cheap alternative, we have signs around here made and fitted years ago they are still ok. 🙄 although do lean towards Di-bond or alternatives.
    24 June 2007 at 21:19
    Tris, as for cutting I use a panel saw but I am sure I have read on the boards that some members cut it with a straight edge and Stanley knife. If you are buying from someone like Europoint they will cut it to size for you which saves you the trouble and the mess :lol1:
  • Tris Gee
    25 June 2007 at 15:19
    thats great , is there an alternative way of fixing to a wall other than screws, maybe adhesive, or does it depend on the surface im fitting to and size of sign. many thanks
    25 June 2007 at 16:05
    Tris, there are other ways of fixing it to a wall if you don’t want any fixings showing on the front face of the sign. The easiest of these would be to either mount the sign in a frame or attach a plastic frame which covers the fixings once it is fitted.
    You could also manufacture or buy in a sign tray which would mean the fixings were in the sides rather than the front of the sign, there is a demo of how to make a sign tray on the boards already.
    You could also use big head fasteners or something similar bonded to the back of the sign.
    Hope that helps a bit, quite a bit more for you to think about now :lol1:
  • Tris Gee
    25 June 2007 at 17:46
    that gives me alot to think about and take in, all usefull info from you all thou, a great help!!
