Home Forums Sign Making Discussions Neon, LED, Lighting Best Glue to use on Polycarbonate
  • Best Glue to use on Polycarbonate
    Posted by Gary Gray on 10 November 2011 at 15:57
    I am trying to find the best glue to use on clear polycarbonate that will dry to a totally clear finish. A supplier would be helpful as well.
    Gary
    Gary Gray replied 14 years, 1 month ago 2 Members · 4 Replies
  • Ian Johnston
    10 November 2011 at 16:27
    MEK (methyl-ethyl-ketone) Lovely stuff, dont breath it too much though!! 😀
    handiest supplier Ebay
  • Gary Gray
    10 November 2011 at 16:49
    Thanks Ian
    How does this differ from dichloromethane methyl methacrylate better known as Tensol 12. This is what I have used recently but it dry’s/evaporates so fast its hard to work with. I have read that Weld-on 4 is perfect for the job but can’t locate it in the UK.
  • Ian Johnston
    10 November 2011 at 17:38
    It different from tensol 12 in that it’s 1/20 the price.
    MEK is basically a solvent for polycarbonate, Put it into a syringe, and offer you two pieces up together, Squirt a small piece into your joint and you have an instant bond as soon as the Solvent evaporates, it’s not fully cured for 24/ 48 hrs but will hold almost instantly.
    The same applies with Dichloromethane for acrylic, cost pennies but is brilliant a Glueing a tight joint.
  • Gary Gray
    10 November 2011 at 18:22
    Cheers Ian
    I will give it a try, do you dilute it or use it neat?
