Home Forums Sign Making Discussions General Sign Topics best adhesive to stick flute board together
  • best adhesive to stick flute board together
    Posted by Paul O'Shea on 24 April 2007 at 13:40
    I have got a job to supply a customer with some advert boards which are made from flute board and they need sticking together back to back but only down the sides so they can be slid down a pole…. Ive used some evo stick no more nails glue but it did not really bond very well. What sort of adhesives have you lot used on flute board?
    any help would be sound
    Thanks Paul
    Nicola McIntosh replied 18 years, 4 months ago 6 Members · 8 Replies
  • 8 Replies
    24 April 2007 at 13:42
    VHB or UHB double sided tape should do it. 3M do a very good one
  • Graeme Speirs
    24 April 2007 at 17:39
    dorotape in the UK are very well priced for the red VHB tape, when I say red it has a red release paper and the tape itself is clear, should do the job no probs.
    graeme
    24 April 2007 at 17:51
    red one is actually the grey tape like you said graeme… 3M stuff comes in white and grey, the white being the better of the two, but i mostly use the grey but accompanied by rivettes.
    you could try corribind from europoint display its for bonding correx aka fluted board, hence the name…
  • James Martin
    13 August 2007 at 15:25
    Hello
    I was searching the boards for a glue to stick laminated pouches to correx flute board so I thought I would hijack this post.
    I’m thinking some sort of glue as I want it to remain a nice flat finish.
    Anyone got any ideas?
  • Adam Triggs
    13 August 2007 at 17:48
    I Started to use glue but found that wasn’t quick enough. So no I use the hot air welder from Lister, Works a treat. I make all sorts with it now.
    Decal pouch (stops them curling), Art work folder, The list goes on.
    Hand held one works, but you have to be steady and quick to get a clean join. The rolling model it best for a straight clean join.
    Awesome bit of kit. But then again it should be for £1700.
    Adam
  • James Martin
    13 August 2007 at 21:23
    Never even knew such a thing existed Adam.
    Something to look into mate.
    tks.
    13 August 2007 at 22:29
    3M do a doublesided tissue thin adhesive tape. We use it here to stick cnc plastic letters to a glossy surface. Works a treat.
    13 August 2007 at 22:57
    corribond from europoint is what i use….. 😀
    but you have to make sure you are able to stick it in one go……..as you cant reposition the boards to the tape once its stuck 😀
