Home › Forums › Sign Making Discussions › Neon, LED, Lighting › Bending and forming foam board
Posted by Stephen Ingham on 1 August 2010 at 20:36Hi all, can anyone recommend a method of bending and forming a piece of say 3 or 5mm foam board?
I have a piece of board measuring approx 1000mm square that i need to put a 90 degree bend in, has anyone ever done this, putting a bend in and it staying there?
Any help and advice is much appreciated.
stephenStephen Ingham replied 15 years, 4 months ago 4 Members · 16 Replies -
Yup.
Used several in the past – some commercial, some home made.
hot line bender is the best way for a crisp, tight line.
Flat table with a heated wire running in a gap – adjustable temp…great for heat-bending most sheet materials.
http://www.shannon.nl/index_ENG/sub/kun … hines.htm#
Home-made versions available!
http://www.mp3car.com/vbulletin/fabrica … -less.html
Hi David, thanks for the reply.
Its probably a little more involved than i had expected….
stephen -
quote Stephen Ingham:Hi all, can anyone recommend a method of bending and forming a piece of say 3 or 5mm foam board?
stephenhttp://hotwirefoamfactory.com/home.php they do have suppliers in the uk
and are also on sale on a well known auction site -
I can only see styrofoam sculpting kit, not PVC / acrylic bending kit on the website.
quote David Rogers:I can only see styrofoam sculpting kit, not PVC / acrylic bending kit on the website.
I use the adjustable heat controller.
quote Graham.Shand:quote David Rogers:I can only see styrofoam sculpting kit, not PVC / acrylic bending kit on the website.
Ah. Gotcha
What’s your setup? A tensioned nickel wire strung over a bench?
quote David Rogers:quote Graham.Shand:quote David Rogers:I can only see styrofoam sculpting kit, not PVC / acrylic bending kit on the website.
Ah. Gotcha
dempends how large the piece is, but I have used a very long wire, but getting a straight line can be tricky, using springs on each end can fix this issue, a self tensioned bow can also be used, various sizes (similar to the "big bow" can be made from pvc pipe, now bending that is a whole new world LOL
we have heat bender, 3mm bends well.
Another way is the router a 2-3mm groove using a 3mm bit into 5mm FX, then use hot-air guns and a long table, put join on table and heat until it bends, using gravity and table edge you would get a reasonable 90deg bend, wont be perfect but it will be bent. Groove facing upwards btw.
quote Dave Rowland:we have heat bender, 3mm bends well.
Dave , perhaps you can help me out here, I have been looking for V shaped router bits for Aluminum, can you recommend a supplier / link, cheers Graham S
Thanks for all of your help and advice.
It is probably only going to be a one off so a simple method is preferred. Would it be possible to route it like you would with composite board when making a sign tray with a 90 degree router bit and then bend it and bond it?
Hope that makes sense?
stephen -
Graham, I bought mine from Axminster but they dont sell them anymore
This will cut dibond, it is trend if i recall correctly and has the 1mm flat.
http://www.powertooldirect.co.uk/trend_ … 79883.htmlStephen, did u read my reply? I would suggest 3mm flat router bit, just a normal one not a V as u bend the other way.
Now, here’s a little trick for using foam PVC if bending is just going to be a lot of hassle.
Personally I’d not be tempted to route & bend with a heat gun as the heat distribution is to random and a clean bend is near impossible unless you drape it over a bench…and pray.
Bog standard cyanoacrylate superglue 🙂
The bond generated with standard superglue on PVC foam board is amazing – MUCH stronger than the actual material.
Try it on some scraps.
you will need very clean & square edges (sawn not knife cut) – NO defects – as the mating surfaces need to be in contact.
Masking tape hinge so you align the edge perfectly – run in a bead of glue, set to 90 degrees…done.
There are even better glues – but they melt the PVC and it gets messy.
quote Dave Rowland:Graham, I bought mine from Axminster but they dont sell them anymore
Cheers Dave, much appreciated
Thanks again for the replies.
Sorry dave, i think i miss read your reply, a flat bit not a "V".
David when you say "Bog standard cyanoacrylate superglue" any clues as to where to buy it from?
That may sound like a draft question, if it is i apologise.
stephen -
quote Stephen Ingham:Thanks again for the replies.
Sorry dave, i think i miss read your reply, a flat bit not a “V”.
David when you say “Bog standard cyanoacrylate superglue” any clues as to where to buy it from?
stephenIt’s just ‘superglue’ – B&Q should sell a nice big bottle of the stuff (20ml or so).
