Begginer with VP-540 and problem with Color Calibration
Couple of days ago I got my self new Roland VP-540. Also I have ordered with it installation and setup. I also ordered some testing vinyls to learn on actually print jobs.
So I downloaded ICC profiles from MultiFix web site since I have their vinyl. But this profile is giving me prints were colors are vary pale and without any contrast or desaturated.
First I’m asking you if it is normal for Roland dealer that he just deliver plotter, makes first initialization, calibrating and short demonstration how does softwear looks. Or should he help me by the end with setting also proper ICC color profile so that at least colors are correct printed with vinyl that he supplied me.
It disturbed me, that after I have called him back and explained the issue that I would need help with making new or customize existing profile, that he is out of time and that actually he can’t help me. Also that in any case I will have to order service for creating custom ICC profile with hardware densitomer and spectrometer like Gretagmacbeth. I was shocked because he didn’t told me anything about this in front. So I called friend which is using dye plotter. He solved this without hardware measurement equipment in such matter that he just simply printed pictures with all ICC profiles and than picked one out which looked like the one he wanted.
In my case this is big problem because VersaWorks has 126 built in color profiles and it doesn’t allow nested job to have separated color profiles. But if I nest couple of jobs, all jobs will inherit settings from the top one. So I wanted to put jobs side by side (from left to right) with different color profiles for comparisment. But VersaWorks allows me only to setup jobs with different color in a column…one behind other…which means I will spent complete 50m of vinyl just to print 10% if it’s width.
So if anybody has some recommendation for beginner in plotter or advice I would be vary happy. So far I have given 5 days and nights for testing and spending a lot of reading on the Internet without major success.
How did you solve this with solvent plotter?
Sasha from Slovenia
