Home Forums Software Discussions General Software Topics Barcode Printing with Roland Versaworks? Help needed please?
  • Barcode Printing with Roland Versaworks? Help needed please?
    Posted by John Cooper on 30 November 2014 at 14:00
    Hi guys
    I printed 1000 labels with an incrementing number using a barcode font from IDAutomation type 39.
    Using the variable data feature in Versaworks, everything was quite easy and the printed labels looked good.
    I’ve always produced barcode labels on the Gerber Edge and they’ve worked as they should.
    Last week the customer contacted me and said the barcodes don’t read! I checked the labels and sure enough, they don’t read! Since, I’ve tried various changes e.g. changing the barcode font size, but nothing works – they just don’t read!
    Just wondering if anyone has had any success?
    Lee Reeves replied 11 years ago 4 Members · 5 Replies
  • Andrew Weaver
    30 November 2014 at 15:45
    Sorry haven’t done any barcodes on the roland, just an idea … could it be the laminate that stops the reading or the colour that isn’t deep enough ??
    I am interested if you find the answer !!
    Good luck
  • John Cooper
    30 November 2014 at 16:08
    Didn’t laminate so can’t be that.
    My final attempt is to rotate the design and then print, if that doesn’t work I’ll get the Gerber working 🙂
  • John Cooper
    30 November 2014 at 16:35
    Turning the label through 90deg, ripping & printing doen’t work either 🙁
  • Warren Beard
    30 November 2014 at 19:46
    Hi John
    Do you have an old one to compare to? If the ink is bleeding a bit it may cause it not to read as it will narrow the gaps between the bars, try making the bars a fraction thinner and try print again.
    Try printing one of the Gerber artwork prints to through VW and see if you get the same problem just to eliminate possibly the barcode generator causing a problem.
    Even just try printing on to copy paper on your desk top printer to test.
    Good luck mate
    Warren
  • Lee Reeves
    30 November 2014 at 21:23
    Is the black 100% black or a composite cmyk black?
