Home Forums Sign Making Discussions Neon, LED, Lighting Banner hemming powertape? Looking for cheapest UK supplier.
  • Banner hemming powertape? Looking for cheapest UK supplier.
    Posted by Scott.Evans on 29 June 2014 at 17:19
    hey, guys do any of you use this power tape instead of hemming?
    we are looking to buy in bulk, do any of you know the cheapest uk supplier?
    £14 is the cheapest i can find
    scott
    Scott.Evans replied 11 years, 5 months ago 2 Members · 3 Replies
    29 June 2014 at 17:40
    We have bought similar from Paperlinx.
    I say similar because i am not sure if power tape is what its called from them. 😀
    we normally use the general method of double sided tape to hem a banner.
    larger banners and joining banners we use a leister banner welder.
    however, when doing large banners we now try to use this "powertape" around the perimetre of big banners for the added strength.
    i don’t know how much we pay for a roll, but keep in mind roll length when comparing prices. bit like vinyl… 50 metres in UK but some rolls of vinyl come in 46 metres or there about because its reeled in 50 yards from the states
  • Scott.Evans
    29 June 2014 at 23:06
    Hi Rob,
    yes the rolls are 33m its seems very expensive for what it is. the manufacture of this is from the US.
    i will look into the tape from Paperlinx.
    do you think its a alternative to hemming.
    Scott
  • Scott.Evans
    29 June 2014 at 23:12
    can only find this from paperlinx
    Fixings – Tapes/Velcro/
    Magnetic
    MST Self Adhesive Mag A Strip Standard Adhesive 13mm x 30m 1500 micron
    PMN Fusion Adhesive Backed Mag A Graphic Standard Adhesive 13mm x 30m 1500 micron
    PMN Fusion Adhesive Backed Mag B Frame Standard Adhesive 13mm x 30m 1500 micron
    VER Velcro Strip and Coins Standard Adhesive 20 / 22 / 25 / 50mm 25m rolls
    HLS Hook and Loop Rolls Standard Adhesive 20 / 25mm 25m rolls
    OBN Orabond banner hemming tape Solvent Adhesive 25mm 25m rolls
