Home Forums Printing Discussions Roland Printers banding and images getting bigger
  • banding and images getting bigger
    Posted by David Hammond on 21 February 2011 at 18:59
    I am trying to print dome display boards on my 640, onto 440 miron PVC. Got the profile off rolands web site, but keep getting banding. Calibrated it, and it still happens. Loaded some into the plotter to cut them, and they’re about 1inch longer!
    Printed using a pick up, and after speaking with roland unravelled a length of pvc off the roll. Still can’t get it right!
    Anyone have any more ideas?
    Printing on 1550 mm pvc, each board should be 606 x 900mm
    David Hammond replied 14 years, 9 months ago 3 Members · 7 Replies
  • 7 Replies
    21 February 2011 at 19:13
    there might be a calibration value in the profile that is over riding your input.
    when i calibrate for length when doing build drawings i don’t care about the quality.
    when i calibrate for quality i don’t care about the length. so never checked.
    my guess is about +.50% calibration for 440 material
    21 February 2011 at 19:48
    What’s the best way to calibrate to lengrh?
  • Matt Rhoades
    21 February 2011 at 20:36
    Chris is right. There’s a calibration issue you have. Sounds like your printer is feeding the media too quickly. Should be a setting in your menu somewhere? Our gs 6000 had the same prob but luckily while the engineer was setting up!! Sorry i couldn’t be of more help mate 😳 Hope you get it sorted.
    Matt
    21 February 2011 at 20:41
    Found the setting in the profile to slow media speed and print head speed down. Not sure what effect these will have??????
    21 February 2011 at 22:38
    adjusting speed will not affect it its the feed amount that’s needs adjusting.
    if you say its 25mm longer than the 900mm sent then i think its set the calibration to -2.5 % if it goes that high.
    but it just all don’t sound right.
    i normally only have to worry about 3mm in 1000. when printing on to 90gsm paper.
    22 February 2011 at 09:06
    Firstly sorry for the short blunt posts, as I was using my Blackberry, and it aint to great for posting on here.
    The PVC is quite weighty, so I can understand it pulling a lot. I might try and move the bench infront of the printer to see if stopping the print hanging helps?
    I will adjust the feed also, and keep you posted.
    22 February 2011 at 09:51
    Been doing some maths this morning.
    Printed the board with the feed cal set to 2.5% as suggested, and took a measurement. I then changed it to 1.5% and measured again. The difference will give me the distance 1% equals.
    From that I can work out what distance 0.01% is, and calculate the correct % to get the correct length.
    I will let you know if it has worked!
