Home Forums Software Discussions Adobe Software Background removal
  • Background removal
    Posted by Adam Ross on 22 September 2010 at 07:48
    I have removed the background from a photo of a person only leaving the person. Which is the best format to save the file too enable me to import it into Corel to allow me too easily place and outline around it for print and cut on my Versacamm.
    Currently it still has the boundary box around it, I need it to have a path following the outline of the figure.
    Many Thanks
    Adam
    Chris Key replied 15 years, 2 months ago 4 Members · 5 Replies
  • Chris Windebank
    22 September 2010 at 08:08
    If you are using Corel there is no need to take the background off, just use the powerclip function then you get a boundary which you can use for cutting.
    Take a look on the net for a few tutorials or videos
    http://www.youtube.com/watch?v=67eN5nfdnTs
    22 September 2010 at 08:13
    i believe who’s using "adobe", but which one?
  • Adam Ross
    22 September 2010 at 08:49
    Many Thanks Chris the tutorial was very helpful.
    I was originally trying to use photoshop CS3 to remove the background, anyone using mask pro 4 ? how does it compare to the fluid mask function in sign lab ?
  • Chris Key
    22 October 2010 at 08:18
    If you’re not competent with the pen tool, you could auto trace in Corel and expand the path, then import the image behind
  • Chris Key
    22 October 2010 at 09:07
    Or if you’re in PS, once you’ve got rid of the background, you can ctrl+click the layer, then do:
    Select > Modify > Expand (set a number depending on your job size)
    You’ll get the marching ants around
    In the path window (Window>Paths) click the Make Path button
    Then File > Export > Paths to Illustrator
    In corel, import both the saved JPG/TIFF and the "path" .ai file
