Home Forums Sign Making Discussions General Sign Topics [b]Glossary of Terms and Materials[/b]
  • [b]Glossary of Terms and Materials[/b]
    Posted by Deleted User on 28 June 2002 at 21:59
    ADA
    The Americans with Disabilities Act, which requires adequate signing for all users, including persons with disabilities
    Backer panel
    a sign panel used to hide mounting hardware
    Channel letters
    a fabricated dimensional letter without a back
    Code-required
    any message or sign that is required by the ADA, state or local building codes
    Dimensional
    letters with depth
    Directional
    any sign that directs visitors to a destination
    Etching
    a method for carving into the surface of a material, particularly metal
    First surface
    the outside surface or front of a piece of glass
    Header
    The primary message or title on a sign, usually the largest message strip and type size
    Infilling
    a process for applying ink to letters that have been etched into a surface
    Millwork
    custom-made wood panels
    Modular
    standard size components which are interchangable
    Mow strip
    a barrier that prevents lawn-mower damage to ground-mounted signs
    Overage
    Extra, blank message strips for a sign, for future name/message changes.
    Pin-mounting
    a method for attaching letters or signs to a surface with a metal dowl
    PMS
    Pantone Matching System, an industry standard color ink system, frequently used for matching colors across materials
    Photopolymer process
    A photographic sign manufacturing process used to create raised letters and braille.
    Reveals
    A narrow, raised or indented line which forms a separation between categories or materials on a sign or archetectural surface or material
    Sandblasting
    a method for carving the surface of a material, particularly glass and stone
    Second surface
    the inside surface or back of a piece of glass
    Silkscreening
    a method for permanently applying graphics to any surface using ink
    Stanchion
    an upright post or support that holds a sign
    Surface-applied
    attached directly to a surface with adhesive (e.g. , silicon, two-way tape)
    Top-coated
    Ink applied to the top surface of raised letters which contrasts with the sign background color
    Touch Screen
    a video or computer monitor which is activated or manipulated by touching the screen
    Typography
    A specific and distinct style of lettering, also called type, typestyle or font
    Vinyl
    a die-cut adhesive material used to apply graphics to any surface
    Veneer
    A thin, surface-applied material
    Digital Print and Devices Terminology
    byte
    8 bits, reflecting values between 0 to 255; used as a basic
    method of measurement of memory or disk size; “K”
    represents 1024 bytes
    color correctness
    the depth and accuracy of an image’s color representation,
    typically influenced by the color depth and palette of an
    color depth
    the amount of color information in an image, reflected in the # of color bits compression, lossless scheme of organizing information in a more compact form where all of the original information is retained, while gaining a moderate level of compaction
    compression, lossy
    where some information is lost to gain higher levels of
    compaction
    cmyk
    the four process colors — cyan, magenta, yellow and black
    — mixed to provide a color image; typically used in printing
    applications
    dib
    Device Independent Bitmap, a variant of a bitmap (bmp) file consisting of header field, an optional pallette, and bitmap data; bitmap has an additional header field
    display quality
    the characteristics of a display sub-system, such as
    resolution, # of colors, dot pitch, and refresh rate, which
    influence perceived image quality
    dithering
    the technique of making adjacent pixels different colors to
    make them appear like a different color; utilized to add the
    appearance of greater color depth with a limited # of colors
    dot pitch
    distance in millimeters between two holes in the shadow
    mask of a monitor. A smaller dp is better, e.g. 0.28 mm is
    better than 0.36.
    dpi, dots per inch
    sometimes termed pixels per inch, this depicts resolution and is a significant influence on the size of an image file; a higher dpi indicates higher resolution
    eps
    Encapsulated PostScript file format, an Adobe Systems
    graphics file which incorporates PostScript code and can
    contain data as vectors or bitmaps; maximum color depth =
    16.7 million
    gif
    Graphics Interchange Format, a lossy compression
    technique, popular for exchanging files electronically,
    especially on Compuserve; all files have a corresponding
    palette; maximum colors = 256
    jpeg
    Joint Photographers Expert Group; a compressed, lossy
    format which is symmetrical, i.e. takes the same amount of
    time to compress as decompress; maximum colors = 16.7
    million
    lpi, lines per inch
    measurement of the frequency of “dots” represented in a
    halftone image
    mpeg
    high-quality video compression/decompression scheme
    (CODEC) for encoding video and audio for computer
    playback
    palette
    data structure defining the colors utilized in a bitmap image;
    bitmap data is indexed to the palette table
    Photo CD
    Kodak CD-based digital imaging format, where images are
    typically created from 35mm film negatives or slides; includes multiple resolutions of an image in an Image Pac, with all images 24 bpp encoded in YCC format; portability includes Philips CD-Interactive and 3DO Players, as well as PC, Mac & Unix viewers; maximum colors = 16.7 million
    pcd
    see Photo CD
    pcx
    ZSoft format, used widely for paint and desktop publishing
    programs; popular for exchanging images; maximum 16.7
    million colors
    PICT
    standard format for Macintosh, can contain both vector and
    bitmap information; maximum colors = 16.7 million
    pixel
    picture element, or the smallest unit of the computer screen.
    A pixel can be monochrome or up to the pixel depth
    available on your color system. Pixels are also used for
    identifying screen resolution, e.g. 72 pixels per inch.
    pixels per inch, or ppi
    sometimes termed dots per inch, this represents resolution
    print quality
    the characteristics of a printing sub-system, such as the
    number of lines per inch and paper quality, which influence
    the perceived quality of a printed image
    quicktime
    a video compression/decompression scheme (CODEC) for
    encoding video and audio for computer playback; originally
    an Apple Macintosh file format, it is now commonly utilized
    on Windows and Unix systems
    resolution
    measure of the detail in an image; the higher the resolution,
    the higher the amount of detail
    RGB
    red, green, blue mixed to provide a color image, typically
    used in video display applications
    TGA
    Targa format developed by Truevision; usually 15 or 24 bit
    full color images, compressed or uncompressed; maximum
    tiff
    Tag Image File Format; industry standard image file format;
    “tags” represent image attributes, compression, and color
    tables; both uncompressed and compressed versions,
    although compressed is not as portable; maximum colors =
    16.7 million
    vector graphics
    image made up of individual objects, which are defined as
    mathematical elements with specific characteristics
    WMF,
    Microsoft Windows metafile DIB record, can be compressed for 4 and 8-bit images;
    Robert Lambie replied 23 years, 6 months ago 2 Members · 2 Replies
  • Andrew Blackett
    29 June 2002 at 11:29
    another good little (i use the term lightly 😉 ) post, found the stuff on digital print quite interesting
    ANDY
    29 June 2002 at 12:00
    excellent posts/tips guys. but could you do me a favour. put under the post at the bottom the name of the site that you have taken the information from. if this is copyright material im afraid ill have to delete it.
    im all for posting information found on the web if it has been put on for this purpose. “shariing” but merely cutting and pasting another sites info is not somthing i would personaly like done to me.
    anyway, put the deltails of the site below this/any, information is taken form & ill go and have a look myself. if i think its ok ill leave it if not ill delete it and send you a personnal message explaining why…
    the same thing goes for clipart & vehicle outlines.
    i would like the site to be looked at as professional as possible rather than warez site or some place to pick up cheap products and pirate software…
    sorry guys… just trying to keep things right 🙄 🙄
