Home Forums Sign Making Discussions Industry News (Archive) AXYZ launch hybrid digital finishing solution
  • AXYZ launch hybrid digital finishing solution
    Posted by .News on 26 November 2015 at 14:44
    Leading supplier of high-performance routing, engraving and cutting systems to the sign and graphics and digital printing industries, AXYZ International has launched a hybrid digital finishing solution that is said to be the most innovative and versatile combined CNC routing and knife-cutting solution currently available. Called the AXYZ Trident, it provides a three-pronged processing capability (router spindle plus oscillating and tangential knife units) within a single powerful production workhorse.
    Trident has been developed to resolve issues frequently encountered by digital print finishers and in particular those that relate to the need to process an ever-increasing range of different flexible and rigid substrates that require a wider, longer and deeper processing capability in addition to having to purchase at least two different types of machine to carry out all of the routing and cutting requirements of digital print finishing. The routing spindle/oscillating/tangential knife-cutting combination works efficiently and harmoniously to handle materials that might prove challenging for traditional routers, whilst increasing throughput by as much as 50 per cent by comparison with other AXYZ machines. Due to the triple-head configuration of Trident, it is now possible to process virtually any flexible and/or rigid substrate, including materials as diverse as aluminium and other non-ferrous metals, aluminium composites (ACM), acrylic and plastics, foamed and corrugated board, vinyl, cardboard and paper.
    Standard processing areas of the machine range from 1524 x 1219 to 2159 x 3048mm, with virtually any length of material accommodated, while the narrower carriage construction contributes to a 12 per cent smaller footprint by comparison with other AXYZ machines. The Trident also incorporates readily interchangeable blade attachments that can be as long as 120mm to enable the more efficient processing of harder, heavier and thicker materials.
    In addition to the narrower three-head processing configuration, other key design benefits of Trident include a rigid steel frame construction to better accommodate more vigorous machine operation, an exclusive live vacuum deck that provides a maximum material hold-down capability and an integrated latest helical rack and pinion system for enhanced routing/cutting precision. These benefits are supplemented by servo-drive motors for high-speed performance and up to 10hp routing spindles to deliver an increased power capability for the more demanding projects. Optional machine enhancements include a radically expanded Automatic Tool Change (ATC) facility for multiple job processing and the AXYZ Vision System (AVS) that ensures fast and precise media registration mark location whilst automatically altering the cutting path to guarantee 100 per cent accuracy.
    For digital print finishers, AXYZ Trident represents a “best in class” production solution that offers greater flexibility, versatility and a more powerful performance capability by comparison with any other digital print finishing alternative solution on the market.
    For further information:
    AXYZ Automation (UK) Ltd.
    Albrighton Business Park
    Newport Road
    Albrighton
    Wolverhampton
    WV7 3ET, UK
    01902 375600
    http://www.axyz.com/
    .News replied 10 years ago 1 Member · 0 Replies
