Home Forums Software Discussions General Software Topics !autocad probs help please!
  • !autocad probs help please!
    Posted by Tecnicasigns on 11 August 2005 at 13:47
    Hi all
    I need to get some SS letters laser cut in times roman. the guy we use says he cant cut them, he doesnt have the font. is there any way i can convert a file to autocad dxf so that he can cut it. he has suggested i manually digitize the lettering 😮 . he says he needs a polyline. i tried exporting an outline of the text from Illustrator but the outline opened in autocad as spline lines. any help would be much appreciated. i have autocad, illustrator, coreldraw to woek with..
    Martin
    Tecnicasigns replied 20 years, 3 months ago 5 Members · 6 Replies
  • George Elsmore
    11 August 2005 at 13:53
    Hi, use coreldraw and export as dxf he should be able to use it in autocad
    George
    11 August 2005 at 14:45
    Try http://www.aidsoftware.co.uk Jim (who runs the site) is very knowledgeable on all things Autocad/CorelDraw and would be able to help.
    Alan
    12 August 2005 at 08:49
    yes, we had this. Spent many times fighting with laser-cutters services
  • Stephen Morriss
    12 August 2005 at 09:55
    The bloke obviously doesn’t know how to use AutoCad, he can convert the spline to a polyline in Autocad, unfortunatly I can’t remember the comand at the moment as it’s been a year or two since I last used it.
    I’ll check for you and post back.
    He may be meaning that he needs the outline as 1 continous entity though.
  • Stephen Morriss
    12 August 2005 at 10:19
    Ok here’s what your laser man has to do.
    Open the file, this will be the spline, he then has to save-as a R12 dwg file, this converts the file to a polyline.
    It’s something to do with the spline that was introduced in R13 but no option for conversion was offered, however the saving as a R12 does the conversion to a fitted polyline.
    Hope this sorts the problem
  • Tecnicasigns
    15 August 2005 at 23:53
    Thanks steve sorted 😉
