Home Forums Software Discussions Signlab Software attribute palette/prime palette
  • attribute palette/prime palette
    Posted by Yammaski on 2 December 2010 at 18:33
    Can somebody give me a bit more info about this palette ?
    You’ve to load a .hft file, but nothing happens then.
    I can’t find it in the manual.
    Yam.
    Ray Wilcox replied 14 years, 12 months ago 3 Members · 7 Replies
  • 7 Replies
    2 December 2010 at 19:34
    not sure what the attribute pallettte is?
    the .hft is is halftone, used for thermal print.
    normally not available unless you have the thermal package,
    can you give a bit more info or a screen shot?
  • Yammaski
    3 December 2010 at 06:07
    Go To : View > Palettes > Show Attributes Palette
    Then this palette shows up under the Shop Palette (colors).
    But, as you say, if this is only for thermal printing, I don’t need it.
    I’ve a Roland SP300i.[/img]
    3 December 2010 at 08:35
    Which version of signlab do you have?
    I dont have an attributes pallette.
    just the ones shown here:
    maybe we are loosing something in translation?
  • Yammaski
    3 December 2010 at 09:13
    Print & Cut 8.
    see img
    3 December 2010 at 09:47
    Must be a translation thing, if when you click on it. the halftone palette appears at the bottom, then that is what it is. like I said it is used for thermal print.
  • Yammaski
    3 December 2010 at 10:43
    not usefull for me then
    Yam.
  • Ray Wilcox
    20 December 2010 at 13:27
    To Clarify, the Attributes Palette and halftone Palettes are one and the same thing. Newer versions of Signlab will refer to it as the Attributes Palette.
    If you have a non thermal printer it can still be of occasional use. Sometimes PDF and EPS files when imported have overprint characteristics to some objects, these will display as a colour with square "Hatching" over them. The Attributes Palette can be used to return this to the more normal "Knock Out" printing and viewing style.
