Home Forums Software Discussions Corel Software Attempting an effect in coreldraw x4
  • Attempting an effect in coreldraw x4
    Posted by Gareth.Lewis on 3 June 2013 at 11:07
    Hello!!!!
    Question time…
    I have a jpeg image of a coat of arms on a white background.
    Is there a ‘button’ or such like in Corel that will allow me to remove the white background, so the coat of arms could be sat on a different coloured background?
    Alan Drury replied 12 years, 5 months ago 5 Members · 5 Replies
  • George Elsmore
    3 June 2013 at 12:32
    open the image corel paint and use the magic wand tool there are plenty of tutorials on google
  • Gareth.Lewis
    3 June 2013 at 12:40
    Thank you George.
    As you can probably tell I dont use corel very often. 🙁
    Tutorials here I come!!!
  • Glenn Sharp
    3 June 2013 at 15:14
    Gareth…
    I don’t have X4 but have a look for cutout Lab under ‘Images’
    you basically just trace round the outside of the image with a highlighter pen and then fill the area you want to keep
    very easy to do but it’s up to you how accurate you want to be with it
  • Gary Birch
    3 June 2013 at 19:06
    Sometimes we run a trace, then weld delete the detail so it is just the outline and then powerclip the original image
    Cheers Gary
    4 June 2013 at 14:32
    A white background is fairly easy to remove in PhotoPaint with the magic wand tool if you also require a cut contour line then Gary’s method would be better.
    Alan d
