Home Forums Sign Making Discussions Neon, LED, Lighting Attaching hooks to dibond for swinging signs
  • Attaching hooks to dibond for swinging signs
    Posted by Nick Tunstill on 19 December 2013 at 17:18
    I have been asked to produce 2 400mm x 500mm signs on dibond to hang outside a community hall from existing hooks. They are only used when council meetings are on so need to be removable. I can do the dibond bit but not sure of the best way to attached some kind of hook system to the long edge so they hand down? Any tips appreciated!
    Nick
    Martin James replied 11 years, 11 months ago 4 Members · 5 Replies
  • NeilRoss
    19 December 2013 at 18:10
    Bore two large holes or slots?
  • Nick Tunstill
    20 December 2013 at 16:12
    Sounds like a simple plan! Thanks
  • Martin James
    8 January 2014 at 20:11
    I have the same issue. The last sign that was in place by someone else used Caribinas the kind that you use for mountain climbing. This hooked into an acrylic sheet. The Caribina failed in the recent storms and he wants another swinging sign. I was going to use aluminium composite, but though it could really do with an eyelet or something, to give it strength.
    Then the other question is what would I use as a chain, and where would I get them from?
    Perhaps I should get it framed as I could then get it with holes built into the frame, which would then mean I wouldn’t need to put holes into the ACM.
    What suplier should I use for that?
  • Ade Brown
    8 January 2014 at 21:45
    Tradesignz in Morecambe have a carabineer style on theirs that u fasten together with a spanner
  • Martin James
    9 January 2014 at 08:54
    Thank you.
    I couldn’t think of what to search for in Google.
    Since then I found some D-Shackles at:
    http://www.signgeer.com/product/d-shackles-551
    I will look into your suggestion too now.
