Home Forums Sign Making Discussions File Swapping Arial Rounded query
  • Arial Rounded query
    Posted by Colin Crow on 2 November 2006 at 14:04
    We have been asked to produce a draft layout matching Arial Rounded font. No problem I thought until I started looking and realised that although I have Arial rounded BOLD at least 6 times, the standard weight font is illusive to say the least. Can anyone help with a substitute or link? I don’t really want to have to pay the thick end of £80 for a draft!
    Colin
    Colin Crow replied 19 years, 1 month ago 4 Members · 7 Replies
  • 7 Replies
  • Cheryl Smith
    2 November 2006 at 14:16
    got the font, dont know how to attach it to this mail, it wont work….grief!
    sure could email to you tho id need your propler email addy
    Cheryl
    Update: I fink I figgured out how to do it!!
  • Cheryl Smith
    2 November 2006 at 14:44
    OOOps, just realised I sent you what you already have, so now you have it seven times!!
    I confess to having a completely blonde day today, soz hon x
  • Colin Crow
    2 November 2006 at 15:07
    Oh well, thanks for the thought!
    Colin
  • John Harding
    2 November 2006 at 18:50
    Colin can you get away with text in bold – then inline the text and lose the outer bit if that makes sense 😕
  • Colin Crow
    2 November 2006 at 18:58
    Hi john, tried this but because the font isn’t even thickness it results in some parts almost disappearing when thinned down using the inline method.
    I eventually found a light extended form of VAG which when I squash up does a fair impression for now, but the right one would be better.
    Colin
  • Jamie Wood
    2 November 2006 at 22:28
    Helvetica rounded may be closer to Arial, as Arial was originally made to
    look very similar to Helvetica without getting sued.
    Cheers,
    Jamie.
  • Colin Crow
    3 November 2006 at 09:02
    Thanks Jamie, but I could only find this in bold too.
    The laugh is that I have been following an example of the sign which is clearly arial rounded regular but when I checked the guidelines again it specifies arial rounded MT bold! So now I have to check back with the design dept to see which is correct.
    Thanks anyway.
    Colin
