Home Forums Sign Making Discussions Vinyl are these pantone numbers available in vinyl?
  • are these pantone numbers available in vinyl?
    Posted by Tris Gee on 19 August 2007 at 07:17
    Ive been given pantone numbers
    Blue 286 and cool grey 8
    just wanted to know if these are available for vinyl
    Tris
    Warren Beard replied 18 years, 3 months ago 11 Members · 25 Replies
  • 25 Replies
    19 August 2007 at 09:30
    who’s vinyl do you normally use? 286 is a ultramarine blue. But I will give you refs if you have a preferred range.
  • Tris Gee
    19 August 2007 at 17:41
    i had my first lot of vinyl from mulberry design and print, it was local to where i work, Birkenhead, and i thought reasonable price approx £6 per roll. The make is Ritrama.
    I was going to try oracal range, that i just found that they do. so either would do pls.
    And would i need 651, 551…?
    Another question, my cutter s max cutting width is 700mm, the max width of vinyl i could get through it is 800mm, are these sizes available? as i need to cut out a box which is 613mm, 3 mm bigger than 610mm vinyl.
    I could poss reduce box down, but worried that vinyl might not go through straight, thus leaving me with a waste
    Any help appreciated!
    Tris
    19 August 2007 at 21:39
    750/60 is a standard size, some times with sprockets.
    Ultramarine doesn’t match your pantone ref, not avery, oracle or mac.
    well not according to my book anyway, but depends how close you need to be.
    19 August 2007 at 21:53
    I would say that colour is an Ultramarine shade of blue ………. I didn’t give any references Peter. It actually sits in between a few shades of Oracal vinyls.
    I’ve been given that reference before and got away with Metamark Ultramarine Blue. It’s not a million miles. 😉
    19 August 2007 at 22:09
    It depends, like I said, on how close a match the client wants,
    but it it is not ultramarine Marcella, the point of PMS is to get an exact match,
    x
    19 August 2007 at 22:13
    Avery do actual panton matched coloured vinyl but ide imagine it wont be cheap.
  • John Childs
    19 August 2007 at 22:25
    quote Peter Normington:
    Yes, in theory, but it doesn’t work in practice.
    Often there is not a direct vinyl equivalent to a Pantone number.
    Even where there is, the vinyl will look different to the Pantone swatch because vinyl is a lot more solid colour than ink on paper, has a lot more density, different reflectivity etc etc.
    Matching Pantone to vinyl is more art than science and usually, unless the client is prepared to pay for custom vinyl, involves compromise to a greater or lesser degree.
    19 August 2007 at 22:33
    John,
    thats what I was saying, if you asked for a pantone match, then that’s what the client wants, I always give them a sample for them to sign off before supply, and explain the difficulty in matching,
    Vinyls, because the are solid colours usually match better than cymk anyway.
  • Chris Dowd
    19 August 2007 at 22:51
    And don’t forget Coated and Uncoated!
    We matched (as best as possible) to Pantone Coated on a job, when the designer looked at it he had created it using uncoated, quite a colour difference!
  • George Elsmore
    20 August 2007 at 06:14
    quote Tris Gee:
    Tris
    £6 per roll 😮
    20 August 2007 at 08:51
    think that might be a typo G :lol1:
  • John Childs
    20 August 2007 at 09:42
    Or a one metre roll. 😀
    20 August 2007 at 11:29
    quote Chris Dowd:
    Good point Chris. I have never been sure what was meant by coated and uncoated pantone shades. I had assumed it meant one was glossy the other matt – can someone clarify this for me?
  • John Childs
    20 August 2007 at 11:38
    quote Phill:
    I’ve always assumed the same.
  • George Elsmore
    20 August 2007 at 11:45
    me 3
  • Warren Beard
    20 August 2007 at 11:49
    Hi Guys
    They are the same colour but printed onto a matt surface and not a glossy surface. The shine on the gloss promotes reflectiveness which makes it appear brighter and also because it is gloss less of the ink is absorbed in to the material. Matt surface absorbs more ink and reflects less so the colour appears dull.
    The 2 swatches are supplied in a pantone book to show what the difference will look like depending on what material you print on to using the same colour ink.
    Hope that makes sense.
    Warren
  • Chris Dowd
    20 August 2007 at 20:31
    Thanks Warren, I wondered what the difference was too, and you explained it well.
    It is surprising how much of colour difference there is in the two though!
  • Warren Beard
    20 August 2007 at 20:34
    No problem, it is hard to believe but then again do you have any idea how many shades of white there are? 😕
    Warren
    20 August 2007 at 23:02
    not exactly how many, Warren but it gives thought to the statement black is black or white is white depends what swatches you are looking at 🙄
  • Lorraine Clinch
    21 August 2007 at 09:27
    I have a few questions about Pantone books, going to start a new thread, so as not to hijack this one 😕
  • George Elsmore
    21 August 2007 at 09:29
    shoot
  • Warren Beard
    21 August 2007 at 09:59
    quote Lynn:
    I went to many colour training courses when I was in the print game and how many times I saw newbies falling for the old "is this white" trick was really funny. They would show a white square and ask if it was white, of course they all say yes, then they bring up another white square and ask if that was white (this square now whiter than the last), and again they all say yes, the instructor does this about 5 times and every time they all say yes thinking it is white when it is not because he keeps putting up another square that is whiter. By the end of it they are all too scared to answer in case he brings up another whiter square. This was how the newbies to the colour game were introduced to the colour white, there are 100’s of shades of white. :lol1:
    sorry for the long boring story
    Warren
    21 August 2007 at 11:37
    :sleep:
    21 August 2007 at 11:54
    :lol1: Just Kidding Warren
  • Warren Beard
    21 August 2007 at 13:05
    quote Phill:
    I know, sometimes you are just Phill of poo :lol1:
    although I bet you enjoyed your nap 😉
