are the sensors in my Roland camm1 cx24 working correctly?
Hi Folks,
A bit puzzled really, are there sensors in the pinch roller lever on the camm 1? My machine stopped mid-cut (very annoying!), and when I set it up again kept getting the message "Er: bad positin" (?).
Did the usual things checked roller positions, cleaned sensors etc, made no difference? Then tried setting with the rollers up, machine decides to work again! Now did I get lucky or are there sensors in, or connected to the roller lever? If there is it would explain it, and I can open up the machine and check connections etc. If there isn’t I can leave well alone. Or in the words of the old saying ‘if it aint broke, don’t try and fix it’, have caused myself headaches in the past not heading that advice!
cheers in advance, Spooky
