Home Forums Sign Making Discussions General Sign Topics Are squeegees personal choice
  • Are squeegees personal choice
    Posted by Ewan Chrystal on 13 February 2014 at 21:43
    Since i started just over a year ago i have used felt squeegees. But i notice so many different types on sale. Is squeegee choice just personal preference or should i be using different types for different jobs?
    Thanks all
    Ewan Chrystal replied 11 years, 10 months ago 4 Members · 4 Replies
  • Kevin Mahoney
    13 February 2014 at 21:49
    Personal preference I guess. I generally use felt for laminated prints with no ap tape.
    Try the white Teflon ones from Metamark for cut vinyl, gives better pressure.
    14 February 2014 at 06:25
    I would say Yes, its down to personal preference. But i would also say you really should try others. I mainly use one squeegee… but i do occasionally chop and change dependant on the application.
    felt blocks are great and yes i went through a period of "only" using them, but you move on seeing benefits of other types. felt tends to flex allot after a few hours of using them. if you move to a thicker one you fell like your holding a brick.
    i like a 3m gold for general vinyl application and glass etch work.
    but avery felt/nylon for wrapping.
    Avery has around 5 of the same squeegee but different types of pvc used.
    orange – softer, flexible, nylon and felt, use on curved surfaces.
    blue – stiffer pvc than orange, felt and nylon, use on both curved and flat surfaces
    white – stiff, teflon type pvc, doesnt scratch the likes of carbon films etc has felt edge also. glides very fast over vinyls. use on flat and gentle curved surfaces.
    i haven’t tried the others avery ones, but there is 3 of a single manufacturer, and all very different from the other.
  • Simon Worrall
    14 February 2014 at 06:42
    I just discovered the teflon ones myself.
    They have less friction and I like the feel of them.
  • Ewan Chrystal
    14 February 2014 at 21:07
    Thanks will try out some others see how i get on
