Home Forums Sign Making Discussions Vinyl Applying vinyl to deep recesses help please?
  • Applying vinyl to deep recesses help please?
    Posted by Gary Thomas on 25 March 2004 at 10:32
    Hi – Can anyone tell me when applying a vinyl graphic to a deep recess to a vehicle whether the graphic should be compensated for the recess so it doesn’t look odd once applied – Is there a recommended depth (low point) on a recess or recommended minimum width on graphic before you should consider compensating the artwork?
    Thanks 😕
    Gary
    John Singh replied 21 years, 8 months ago 6 Members · 6 Replies
    25 March 2004 at 11:00
    do not compensate for recesses, you leave yourself wide open to various other problems arrising.
    the best thing to do, if you can, is keep this in mind when designing a layout. 🙄
  • Gary Thomas
    25 March 2004 at 11:26
    Thanks for the advice Robert.
    Gary 😀
  • Andrew Ward
    25 March 2004 at 16:36
    Can i add…..
    Depending on the Job/Customer, Sometimes i apply the graphics to the flat areas, then cut the vinyl where it crosses the recess & use my finger to stick the vinyl into the recess.This then leaves a gap which you join with a spare bit of vinyl. If you are clever where you make your join, I.E. where the panel creases are, it can be hard to see a join at all.
  • kev hoy graphics
    25 March 2004 at 22:00
    i agree with both wardie and rob on this one.
    try and avoid the pits when designing but if you cant. wardies method is a good one too. i use this from time to time. 🙄
  • davidsignmaking
    1 April 2004 at 14:45
    yea i agree too try and stay from the pits
  • John Singh
    1 April 2004 at 20:50
    Yeah! Mum used to tell me to stay away from the pits
    Used to always end up getting a belt from me dad though!
    Pittance advice really
