Home Forums Sign Making Discussions Vinyl Applying Vinyl To Decorative Wall Panel – Help Needed
  • Applying Vinyl To Decorative Wall Panel – Help Needed
    Posted by Peter McGarry on 8 December 2013 at 12:46
    Hi All
    Long time since I have posted on here, although I do view the forum almost daily.
    Hoping someone can clarify a point I have regarding applying vinyl text (approx 500mm W x 1700mm H) to some decorative panels that have been installed at a business local to me.
    The panels are fitted to the entrance of a sales office/showroom that is accessed from the warehouse. The panels are sealed MDF with "V – shaped" grooves running vertically, approx every 100mm, the full length of the panels.
    I intended to use a matte cast vinyl, (KPMF 7100) due to the grooves, but my question relates to the actual application.
    Can someone confirm the best way of applying?
    Do I squeegee the vinyl on flat first and then work it into the grooves or work the vinyl into the grooves as I go along ?
    Am also intending to lightly heat the vinyl as I apply it due to the warehouse being so cold this time of year.
    Peter McGarry replied 11 years, 11 months ago 1 Member · 2 Replies
  • Peter McGarry
    8 December 2013 at 13:05
    Just to give you an idea of what is involved…..
    [/img]
  • Peter McGarry
    9 December 2013 at 16:34
    Sorted – fairly easy actually. Shame about my camera skills though.
