Home Forums Sign Making Discussions Vinyl applying vinyl over panels
  • applying vinyl over panels
    Posted by Matthew Greer on 17 March 2009 at 18:04
    If I am fitting vinyl lettering to the side of a can that has lots of panels and I have lettering going over Joins how is it best to apply the vinyl? Is it better to go straight over it then heat it up with a hot air gun or work in into the join while fitting.
    A few pics to show you what i mean:
    Now with this pic imagine you are looking down the side of the van rear to front.
    Ian Jenkin replied 16 years, 8 months ago 5 Members · 9 Replies
  • 9 Replies
    17 March 2009 at 18:26
    when ever possible
    feed the vinyl in, if you need to heat it in on a double crve for instance, only do it with a suitable Vynyl
  • Matthew Greer
    17 March 2009 at 18:32
    Cheers Peter, what kind of temp are you looking at to heat the vinyl to?
    17 March 2009 at 18:42
    Warm the vinyl till it looks happy,
    You can see it start to tighten/shrink a little, then once you have fed it in you need to heat to the recommended temp to fix its memory, check your with your manufacture for recomended temp.
  • Ian Jenkin
    17 March 2009 at 20:01
    Matthew, as Peter says, the heating once applied is always the part people seem to miss.
    A nice analogy (is that the word?!) Peter – "fix its memory" – sounds very professional!
    17 March 2009 at 20:30
    quote :
    = approx 40 ish deg 😀 😉
  • John Childs
    17 March 2009 at 21:38
    Feed it in every time.
    Anything else is asking for trouble later.
  • Matthew Greer
    17 March 2009 at 22:58
    How about if I was fitting a big logo/disc over the panel would I have to use some kind of vehicle wrap vinyl.
  • John Childs
    17 March 2009 at 23:20
    quote Matthew Greer:
    For that, yes.
    If only going over straight swages, then you can get away with calendered vinyl, fed in. If you have to stretch the vinyl in any way, then, yes, a wrap vinyl or, at least, a good cast.
  • Ian Jenkin
    18 March 2009 at 05:58
    Matthew, we do similar vinyls for a customer using Avery 900.
