Home › Forums › Sign Making Discussions › Vinyl › Applying Digital Vinyl to MDF panels
Posted by Dean Brabin 1979 on 20 May 2024 at 10:34Hi Sign People
Just a little help is required in confirming…
Can I apply my digital sign vinyl directly to MDF unpainted panels ??
Are there any issues with doing so like the glue being absorbed by the panel and the digital vinyl becoming loose or unstuck after X time etc…
Any help or guidance on this would be greatly appreciated
Dean
Mark Johnston replied 1 year, 5 months ago 5 Members · 7 Replies -
Needs to be at least primed for a good bond, while its possible, I would not recommend it.
Thanks Colin for the help – Ive sealed the panels before hand
Hi Dean
Can it stick? yes.
Will it last? is anyone’s guess.As @Colin-Crabb-1 has said, you would want it to be primed at the very least.
then maybe a thin gloss coat if possible… even then, once you have it fitted, make sure you apply gradual heat over the surface while rubbing over it firmly with a soft cloth or felt squeegee. the heat and pressure will help promote the bond better.MDF is smooth and will allow things to adhere to it.
But microscopically, it has a fluffy fibre surface. That’s what your vinyl is sticking to.The digital vinyl on the other hand, is it, monomeric, polymeric, or cast… then what series and brand of vinyl?
there are many variables and each one will have different types of adhesive and percentage of shrinkage. Ultimately deciding on how successful the application would be.let’s say a polymeric with an air-release adhesive system. right there there is less adhesion to the surface due to the adhesive than one without air release.
The adhesion is probably around 30% less of a bond and it has been fitted to that fluffy fibre surface, i would say it’s now lost at least another 20% of its optimal bond.
Now take the shrinkage of the vinyl…
Monomeric digital is the worst, Polymeric is the average and Cast with the least shrinkage.
So the vinyl wants to curl/shrink/pull back, and all it has to help prevent this from happening is it’s 30% less grip adhesive trying to bond onto the fluffy fibre surface, so there is another 20% loss.
Even if using a polymeric, there will be shrinkage of some kind. So I would say that there is at least a 60% more chance of a failure, over time than if it was applied to the likes of a composite board.I know you probably guessed most of this anyway, Dean, or you wouldn’t be asking for confirmation, mate. I am just trying to explain it a bit…
Also, you may hear people say, “wrap it around the edge of the sheet onto the back of the composite” and it won’t shrink. it will still fail. it may take a bit longer to fail but it will. worse still, you would be wrapping around MDF and the edge fibres will prevent any real adhesion happening at all. so it will be touching, but not bonding to the edges.
untreated MDF, dependent on its environment, will absorb moisture, from the back or sides.
a similar thing I see occasionally is people wrapping newly filled and sanded vehicle body parts, or unpainted wings of a car or something. the same thing applies, can it be done, yes, should it be done, definitely no.
i wouldn’t chance it for somthing that was to be on for any more than a month.
Thanks for the help – Ive sealed the panels before hand
Wow that’s great help many many thanks
we have wrapped MDF panels in the past. not big ones they were around 600mm square by 15mm thick.
i was fitting window graphics for the same customer several weeks later and i noticed some parts of the edges had come away so i trimmed them off completely. you can see the vinyl isn’t holding on as good as it was when we finished them.
