Home Forums Sign Making Discussions General Sign Topics Application tape problem, help please?
  • Application tape problem, help please?
    Posted by phillip lloyd on 6 March 2015 at 08:39
    hey all im new to this fourm im phill and im from wales.
    i recently bought orafoil application tape to lay up for first time
    when i layed up on a car wet the applicatation tape didnt want to leave go of the vinyl
    anyone had this problem before ?
    i tryed to apply heat but this made it worse
    Robert Lambie replied 10 years, 10 months ago 3 Members · 4 Replies
  • Stuart Drynan
    6 March 2015 at 09:01
    I cant say i have ever applied a graphic wet using app tape before, but i can only assume that its because you have done so that it has broken down the glue in the tape.
    My suggestion would be to dry the tape fully before removal
    6 March 2015 at 09:03
    The problem is not the application tape, the problem is you applied it wet.
    you will need to squeegee the water beneath the tape out using firm squeegee motion.
    you will need to leave the vinyl in place for long enough to allow the vinyl to adhere.
    spraying the tape with water "after" application and squeegeeing sometimes helps break down the tapes adhesion to the letters.
    all this is pretty useless if the metal of the bonnet is "cold" because it will take much longer for any sort of adhesion build up. try warming the surface with a heat gun.
  • phillip lloyd
    6 March 2015 at 12:43
    thanks for the replay guys will try it again tonight on another car buy heating panel and try it dry
    6 March 2015 at 13:08
    if doing it dry, dont heat the panel unless very cold.
    once it has been applied and tape removed, then heat the panel to promote adhesion.
