Home Forums Software Discussions General Software Topics Anyone using onyx? or specifically onyx 11? Help with tiling options
  • Anyone using onyx? or specifically onyx 11? Help with tiling options
    Posted by Martyn on 3 September 2020 at 11:00
    Hi. I have a large sign to do. 4m by 1.9m.
    The sign is being done out of 4 panels and im trying to get my head around onyx tiling as i want to have bleed on both edges of the panel. Cant for the life of me work it out and for some reason the tiling preview is not showing any overlap when i change the amount. Overwise i need to try and set it up in illustrator but i know it shouldnt be done this way.
    Any help would be much appreciated.
    Martyn replied 5 years, 3 months ago 2 Members · 2 Replies
  • Kev Mayger
    3 September 2020 at 12:26
    Hi Martin
    Either way is correct. Open your job in Onyx Job Editor and go to the 3rd tab along Tiling set up. Click enable tiling, this will allow you to set your panel sizes and overlap. If you choose 60mm overlap you will get 30mm bleed.
  • Martyn
    3 September 2020 at 12:43
    Hi kevin. Thanks for your response mate. When you add your overlap does it show the lines? as when i add different values it seems nothing is happening
