Home Forums Printing Discussions HP Printers Anyone recommend a 1370mm stay flat roll up material?
  • Anyone recommend a 1370mm stay flat roll up material?
    Posted by Ron s fothergill on 13 September 2018 at 11:19
    Hi guys,
    Had nightmares trying to solve this issue. I can run the 914mm versions of any roll up 300mic material fine but as soons as we go larger we get creasing in the back, and then by dropping to 80 degrees as HP have recommended cureing and colour issues. Apparently no Hybrid PVC/Polyester mix are 100% compatible. So were looking away from our normal suppliers which always use the Aquabond so flat, just rebranded.
    Any recommendations?
    Ron
    Kevin Busby replied 7 years, 3 months ago 3 Members · 3 Replies
  • David Gwyndaf Povah
    13 September 2018 at 14:29
    we use the papergraphics tru300 rollup material in both 914 and 1372 never had any problems with it
  • Neil Danley
    13 September 2018 at 16:26
    We use a company called SEDO in Essex who we also bought the kit off. The supplies guy there is called Luke Woodford I think.
    Comes out dry as a bone on the Epson! :thumbsup:
    Neil D.
  • Kevin Busby
    14 September 2018 at 07:27
    For the last 3 years ive been using Tru 300 from paper graphics without problem but not in the wider version.
    Before I used a version from link ink 300 in 1520 and had no problems with that.
    Any Allprint have just bought out a display 300 which are giving me very good results even at higher temperatures but again not tried the wider on this.
