Home Forums Printing Discussions General Printing Topics Anyone had this problem?
  • Andrew O Brien
    26 October 2017 at 20:51
    Presumably it’s in the direction of print? How’s the test print looking?
  • Kevin Desmond
    27 October 2017 at 12:52
    quote Andrew O Brien:
    Yes its in the same direction, and the test print is normally spot on only one maybe two notches at most missing.
  • Jamie Dale
    27 October 2017 at 21:36
    ink starvation more than likely. When was it last serviced
  • Alex Crosbie
    28 October 2017 at 12:58
    Is it only on one media?
    Is this a new media or have you been using it a while?
    What temperature have you got your heaters on?
    My first guess would be try upping the heaters
  • Kevin Desmond
    28 October 2017 at 15:12
    quote Jamie Dale:
    Will check with the Manager on Monday, how often would you recommend servicing?
  • Kevin Desmond
    28 October 2017 at 15:14
    quote Alex Crosbie:
    Its the grafityp matt material also happens on some gloss material.
    Think its on the standard settings, change the heater and dryer settings in versa… how much 5c or 10c?
  • Alex Crosbie
    28 October 2017 at 15:16
    I would try upping 5 degrees and then try it, you can adjust temperature while it’s printing to see if it makes any difference but it does take a little while to raise the temp
  • Kevin Desmond
    28 October 2017 at 15:17
    quote Alex Crosbie:
    Thanks mate will give it a go [emoji106]
  • Chris Wilson
    28 October 2017 at 18:49
    We got this on the Grafityp banner when I order a roll once. Used to drop in and out. However I used to only use a pinch roller at each side. Put the whole rack in and this sorted it for me.
